Old 06-11-2015, 10:12 AM   #1
Movie will not play on tv
Hi everyone, I need help. I have a shamrock camper with a genesis stereo deck. I want to play movies. I have 3 wall outlets. I assume one for roof antenna and one for cable. The other, I'm not sure (coax will not screw into that one). I can hear the movie playing thru the camper speakers, but I get no picture. I have cycled thru all the tv settings and still nothing. Can anyone out there help?
jscraig is offline   Reply With Quote
Old 06-11-2015, 10:23 AM   #2
urocav2001's Avatar
Is the yellow av cable plugged in?
urocav2001 is offline   Reply With Quote
Old 06-11-2015, 10:36 AM   #3
No. I don't see anywhere to plug one in on the deck.
Old 06-11-2015, 11:06 AM   #4
urocav2001's Avatar
On my 13 there is a yellow plug that plugs in to a av port on the side right behind tv
Old 06-11-2015, 11:06 AM   #5
urocav2001's Avatar
I'll post a pic when I get home in about an hour
Old 06-11-2015, 11:12 AM   #6
Jimandchris's Avatar
Hi, there should be a video and audio cable coming from the genisis player to the rear of the tv. Ours is coming thru a separate panel located above the tv mount. Perhaps they are not connected?
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 06-11-2015, 11:49 AM   #7
urocav2001's Avatar
Mine looks like this Click image for larger version
Name:	ImageUploadedByForest River Forums1434041375.377421.jpg
ID:	79629Click image for larger version
Name:	ImageUploadedByForest River Forums1434041388.150038.jpg
Old 06-11-2015, 12:46 PM   #8
Ours you play through the radio you to go to n menu and select the input av1 is radio av2 is the cd player (video player)
Myrle is offline   Reply With Quote
Old 06-17-2015, 11:42 AM   #9
My player was hooked wrong from the factory, did the same thing. Took out the stero changed point of connection and problem solved
time2fury is offline   Reply With Quote
Old 06-25-2015, 10:44 PM   #10
Hi jscraig,
I had the EXACT same problem in our 2014 Sabre with the Genesis system. I ended up pulling my Genesis system off the wall and found that the HDMI cable from the back of the Genesis was not plugged in. The HDMI cable runs from the Genesis down to the TV HDMI input. You need to check that for sure. If you have voice/audio I think this is the problem. Let us know.
JoeNanMinn is offline   Reply With Quote
