Old 11-26-2013, 10:15 PM   #1
Zwicker's Avatar
Mr Heater?
I have a Shamrock 183. Just wondering which Mr Heater I would want for fall or winter camping. How long does a 1lb tank last or just get a adapter hose for the 20lb tanks? Buddy? Big Buddy? Etc...
Zwicker is offline   Reply With Quote
Old 11-26-2013, 10:27 PM   #2
HONDAMAN174's Avatar
I use just a little buddy on low when boondocking. Provides good heat- the higher setting might melt something I always worry. A 1lb last about 7 hrs on low. If going to be a cold weekend I use the 20 lb hose- something like 200 hrs on low.
Just glad to get away
Old 11-26-2013, 10:39 PM   #3
Zwicker's Avatar
Mr Heater more efficient than the furnace? Better heat? Less condensation?
Old 11-26-2013, 10:43 PM   #4
Does not use any power like the furnace power hog does. I've had the furnace kill my battery in 2days. Part of the reason why I got a buddy.
Old 11-26-2013, 10:49 PM   #5
Zwicker's Avatar
Buddies have batteries? Or just some of the models?
Old 11-26-2013, 11:09 PM   #6
My little buddy does not. Can't speak for the larger versions.
Old 11-27-2013, 11:08 AM   #7
MtnGuy's Avatar
We opted for the Big Buddy Heater. Even on low, and with 2 windows cracked, it does a good heating our camper. The Big Buddy Heater has 2 propane canisters that will last about 10 hours on low. The Buddy Heater only has provisions for 1 canister, and will not last all nite. I don't want to get up in the middle of the night to change canisters.
The Big Buddy Heater uses a battery to power a small fan. The fan does not need to be used.
I always crack a window near the heater, and another in the bedroom area. I also make sure the CO detector is working properly.
Old 11-27-2013, 11:22 AM   #8
Great Horned Owl's Avatar
Where do you plan on using it? The Buddy has a low oxygen sensor that is a nice safety feature, but also prevents the heater from operating at altitudes above around 6,000 ft.
If you want to use a ventless heater at higher elevations, you should look at one of the three Olympian Wave catalytic heaters by Camco. I have mine mounted on a wall and plumbed directly into the RV's propane system.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 11-27-2013, 11:58 AM   #9
Originally Posted by Great Horned Owl View Post
Where do you plan on using it? The Buddy has a low oxygen sensor that is a nice safety feature, but also prevents the heater from operating at altitudes above around 6,000 ft. If you want to use a ventless heater at higher elevations, you should look at one of the three Olympian Wave catalytic heaters by Camco. I have mine mounted on a wall and plumbed directly into the RV's propane system. Joel
It does? Huh... Mine works fine at 9000 ft. And I set it right next to CO detector- never goes off. Maybe I got lucky with a defect!
Old 11-27-2013, 12:59 PM   #10
Any unvented space heater will add water to the air because it is a product of combustion. So the Buddy heaters will increase humidity, as will catalytic heaters, relative to the use of the furnace.
And just to be clear, Mr. Heater has four heaters in the "Buddy" line.
Big Buddy - 4,000, 9,000, and 18,000 BTU/HR
Hunting Buddy - 6,000 - 12,000 BTU/HR
Portable Buddy - 4,000 and 9,000 BTU/HR
Little Buddy - 3,800 BTU/HR
Some people call the Portable Buddy the "Little Buddy." Many web sites refer to it simply as the "Buddy Heater"
Just to add ot the naming confusion, the manual provided online for the Little Buddy refers to it as the "Basecamp."
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 11-27-2013, 09:30 PM   #11
biken201's Avatar
We have a Portable (med sized) Buddy and it does a nice job heating the interior of our 233S when needed. It does not need a battery or other electric source.
I don't know how long a single small tank lasts, but I usually bring two, and also an extra 20# tank with a Y connector to run my WeberQ and Coleman stove.
I have the refill adapter to fill the small Buddy tanks from the larger tank when needed. More gas than needed, bit peace of mind.
11' Dodge Ram 3500 DRW 6.7 Cummins
12' Rockwood Roo 233S
Current: AZ
Wife: NY
Me: IL
3 Akitas (RIP D-Dog)
biken201 is offline   Reply With Quote
Old 11-27-2013, 09:49 PM   #12
Zwicker's Avatar
Which adapter do you have? I heard some don't work great? Don't fully top up the 1lb tank.
Old 11-27-2013, 11:56 PM   #13
biken201's Avatar
I purchased mine from camping world.
http://m.campingworld.com/shopping/i...-adaptor/55151
Does it fill the 1lb bottle completely? Beats me, but it fills it full enough.
Current: AZ
Wife: NY
Me: IL
Old 11-28-2013, 03:07 AM   #14
sail2liv's Avatar
When filling the little bottles from a 20 lb seems like they do only fill about half full....make sure the big bottle is upside down to get max in the little....
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 11-28-2013, 06:05 AM   #15
Engineer of Crazy Train
ChooChooMan74's Avatar
Also, the bigger yhe temperature difference between the 2,the more filled it will be. If possible, put the 1lb in the freezer.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 11-28-2013, 07:15 AM   #16
Ford Idaho's Avatar
Yep, this is what I have read the one pounder must be cooled down.
Old 11-30-2013, 09:45 AM   #17
Zwicker's Avatar
Thanks you! So much knowledge on this site! Saves me all that trial and error, not to mention wasted money on junk!
Old 11-30-2013, 11:45 AM   #18
Rolling Magic's Avatar
I agree, rarely use my rig's furnace. I have a Mr. Heater and low setting works best. Once it's time to go to bed, we shut down the heater and pile the blankets...
Rolling Magic is offline   Reply With Quote
Old 01-17-2014, 11:25 AM   #19
Zwicker's Avatar
Thank you all again. Just picked up the Hunting Buddy! Now, where does everyone set it and aim it when it's on?
Sent from my SGH-I757M using Forest River Forums mobile app
Old 01-17-2014, 12:13 PM   #20
NELA
Weezer's Avatar
Our camping companion couple has two of the Buddy Heaters that they use outside in cold weather, as they both smoke, and don't smoke inside.
Inside they use one of these to supplement their furnace:
Keystone Electric Stove - Bronze - World Marketing ES5132 - Electric Fireplaces - Camping World
Nice!
We've used a small ceramic heater in the V-Lite, back in the bathroom to supplement the electric fireplace in the LR area when not using the furnace.
I think I want one of those Keystone heaters to put on the step landing of the 5th wheel for the same purpose.
Are ya'll using propane "space heaters" inside the camper? Yes, I know our campers have CO detectors, but I'm paranoid about heaters indoors.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
expandable, hybrid, shamrock
