Old 09-06-2015, 12:45 PM   #11
I agree with BigJohnD, Barker hands down.
tomrob1161 is offline   Reply With Quote
Old 09-06-2015, 09:45 PM   #12
Engineer of Crazy Train
ChooChooMan74's Avatar
Looks like a lot of people like the Barker. Is it called a barker because it sounds like a dog
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 09-07-2015, 01:07 AM   #13
Just a member
kandl's Avatar
Originally Posted by ChooChooMan74 View Post
I have the brackets with the mount point forward. Reese installation instructions show it as optional.
Ours too and that's ok as long as the cam arm upper connection is ~20 inches from the center of the coupler's ball socket. That will afford the best adjustment range for the cam arms.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 09-07-2015, 01:09 AM   #14
Just a member
kandl's Avatar
Indeed. If the LCI ever craps out, we'll probably start barking too.
Old 09-07-2015, 01:24 AM   #15
Just a member
kandl's Avatar
Originally Posted by youroo View Post
Which way are your adjustable Cam arms Pointing In or Out?
If the cam arms are pointed in, it follows that the snap-up brackets would be pointed in too? Oooh - that's gonna be a PITA!
Old 09-07-2015, 06:47 AM   #16
mcmartinez's Avatar
Should the hanger brackets be bolted into the TT?
Mario Martinez
2703WS Rockwood Super Lite (6,400 Dry weight)
Tow Vehicle - 2010 Ford F-150 Super Crew
5.4L V-8 6-spd auto 2x2 9,800 Lbs. towing capacity.
mcmartinez is offline   Reply With Quote
Old 09-07-2015, 01:26 PM   #17
Just a member
kandl's Avatar
The hanger brackets connect the cam arm to the chain and snap-up brackets. You're thinking of the snap-up brackets?
Name:	Reese DC Strai-Line.JPG
Old 09-07-2015, 01:39 PM   #18
thestrangebrew's Avatar
Got a Barker VIP (3500?). Can't remember exactly the # but they have great customer service and no issues with their products.
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR
thestrangebrew is offline   Reply With Quote
Old 09-07-2015, 03:19 PM   #19
mcmartinez's Avatar
My Bad, yes Snap-Up brackets. Do they need to be bolted or welded to the trailer. Mine seem to slide although they are screwed down pretty tight.
Mario Martinez
Old 09-07-2015, 03:37 PM   #20
Snap ups are usually held in by pressure of a bolt in the back. If you're are sliding, either the back bolt is not tight enough, or, you don't have enough links between your bars and the snap ups.
Locomotive Engineer
