Old 12-31-2017, 02:27 PM   #11
dbledan's Avatar
Originally Posted by A32Deuce View Post
They sell a part called SaveAJack. One piece bolts to the Jack, the other bolts to the frame. Two clips to hold on frame part. Allows you to remove for transport and no worry of damage during transport. In other words, nothing hanging down to catch the ground. I'm using them on my trailer.
Those are nice. I may look into those more for jacks added near my axles but they seem pricy for what they are. Cheaper to get new jacks once but not twice. Who would have thought that CW had them cheaper as well.
dbledan is offline   Reply With Quote
Old 12-31-2017, 02:46 PM   #12
Post
Originally Posted by n0ms View Post
I think i had the same mishap. When you mount the new stabilizer jacks. Run a string from the bottom of the back bumped to the bottom of rear tire. Mount the new jack forward, inside the tire string angle. This makes it harder to rip the new rear jacks off.
Good idea!
Also, you can just use removable jacks, (I use them as stabilizers instead of the levelers, once the coach is first leveled).
https://www.amazon.com/Eaz-Lift-Stab...ords=saveajack
Name:	Eaz-Lift 24 inch RV Stabilizing Scissor Jack.jpg
Cuban Crisis Vet
2017 Forest River SunSeeker 3050S
Ford 450 Super Duty
Just me and the Wife
emeth is offline   Reply With Quote
Old 12-31-2017, 03:23 PM   #13
amblt's Avatar
Originally Posted by cavie View Post
Just remember. Rear scissor jacks are not Jacks. They are stabilizers. Big difference. People seem to ignore this.
I needed to replace 2 stabilizers, went to my local auto supply (Canadian Tire) and got 2 real scissor jacks, planning to have my local weld shop fabricate brackets. Not too expensive, and much stronger than the originals.
Cheers.
amblt is offline   Reply With Quote
Old 12-31-2017, 03:32 PM   #14
Cheers.
What would concern me with this approach is that the stronger you make the jack, the more you endanger the frame if you snag one,.
johnbryanpeters is offline   Reply With Quote
Old 12-31-2017, 03:34 PM   #15
Cheers.
BINGO !!! Did that to my popup in 84. The stabilizers from the factory wouldn't hold up a tricycle.
TheWolfPaq82 is offline   Reply With Quote
Old 12-31-2017, 04:44 PM   #16
Check at “e trailer “
Big Bill is offline   Reply With Quote
Old 12-31-2017, 05:10 PM   #17
Bene Gesserit Rule
Murbella7's Avatar
Originally Posted by TheWolfPaq82 View Post
Scissor Jack / Stabilizer Jack, they do the same thing, designed the same way and roughly serve the same purpose. Slide a scissor jack under a trailer and it becomes a stabilizer. Just saying. If they truly wanted to stabilize a trailer, they'd mount "Outriggers" on the sides like they do to motorized crane's.
I'd like to see that. I'd also like to see where you could park the thing for a stay-over.
Murbella7 is offline   Reply With Quote
Old 12-31-2017, 05:20 PM   #18
Campgrounds with REALLY WIDE PADS.
Old 12-31-2017, 05:20 PM   #19
lugoismad's Avatar
Go to a salvage yard and grab 2 matching jacks out of similar cars. Eg, 2 GM W-Bodies (Grand Prix, Buick Regal, Chevy Lumina). You'll get them a lot cheaper than buying new.
lugoismad is offline   Reply With Quote
Old 12-31-2017, 05:28 PM   #20
i had to drill a couple of holes
locogk is offline   Reply With Quote
jacks
