Old 12-31-2017, 12:10 AM   #1
thestrangebrew's Avatar
Need new pair of rear scissor jacks
Are the rear scissor jacks universal? I had a bit of a mishap which requires me to get new ones for the rear. Are they universal or ar ethe bolt patterns different and I need specific jacks? If specific, which ones do I Need? Thanks!
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR
thestrangebrew is offline   Reply With Quote
Old 12-31-2017, 02:57 AM   #2
dbledan's Avatar
Not sure on bolt patterns but you will need to match height and weight limits for them to work.
dbledan is offline   Reply With Quote
Old 12-31-2017, 06:05 AM   #3
Most bolt patterns are universal. I had to replace mine also. Got them on Amazon. There are only a few manufacturers. As mentioned previously, they are sold by weight limits. A hybrid like yours will be in one of the lower weight classes, therefore cheaper.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 12-31-2017, 07:02 AM   #4
cavie's Avatar
Just remember. Rear scissor jacks are not Jacks. They are stabilizers. Big difference. People seem to ignore this.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Newley Retired.
Old 12-31-2017, 10:46 AM   #5
Do you how to tell which 1 will work best for my Roo? Or where I can find the info? And yes I meant stabilizers! Had a bit too much to drink last night haha
Old 12-31-2017, 10:53 AM   #6
Look at the ones on the camper now. They will have a weight capacity stamped on them, like 1500 lbs, 2000 lbs,etc. Don't get new ones with less capacity. More is ok.
Jim and Deb
2013 Ram 1500
Old 12-31-2017, 10:57 AM   #7
Perfect thanks for the quick reply!
Old 12-31-2017, 11:07 AM   #8
Scissor Jack / Stabilizer Jack, they do the same thing, designed the same way and roughly serve the same purpose. Slide a scissor jack under a trailer and it becomes a stabilizer. Just saying. If they truly wanted to stabilize a trailer, they'd mount "Outriggers" on the sides like they do to motorized crane's.
TheWolfPaq82 is offline   Reply With Quote
Old 12-31-2017, 02:21 PM   #9
A32Deuce's Avatar
They sell a part called SaveAJack. One piece bolts to the Jack, the other bolts to the frame. Two clips to hold on frame part. Allows you to remove for transport and no worry of damage during transport. In other words, nothing hanging down to catch the ground. I'm using them on my trailer.
2012 SunSeeker 3100SS Toad-1962 Futura
A32Deuce is online now   Reply With Quote
Old 12-31-2017, 02:25 PM   #10
I think i had the same mishap. When you mount the new stabilizer jacks. Run a string from the bottom of the back bumped to the bottom of rear tire. Mount the new jack forward, inside the tire string angle. This makes it harder to rip the new rear jacks off.
n0ms is offline   Reply With Quote
jacks
