Originally Posted by kellieh04
Thank you! I was wondering gljurczyk if we could run the propane or not. The thing I was wondering about is if that would burn up my hot water heater if it doesn't have any water in it. Can I turn off the propane from my hot water heater?
Your very welcome and the post #5 is correct. You should have a switch with a little red bulb next to it "Should say DSI" on the panel inside, that is your propane switch for it. DO NOT TURN IT ON, on the outside of the unit where the W/H is located drop the white panel and in the lower left hand corner there should be a black switch, might still have a cotterpin through it make sure that is off, that is for your electrical element. LEAVE THAT OFF. Then you are set to go my friend try the rest out......
