Old 08-08-2015, 09:40 AM   #31
Hi we have a 2015 Ike's we love it but some issues right from the 1st time we used it the rear in line water filter inside the rear door once hooked up would just spin off n flood everything happened twice an all was on right water is not what u wanna see especially if u are away from your camper an its flooding everything so I took it out n made a box to put it before the I let outside its great no more worries others owners had the same problemClick image for larger version
Name:	ImageUploadedByForest River Forums1439044786.961045.jpg
ID:	85129Click image for larger version
Name:	ImageUploadedByForest River Forums1439044824.227162.jpg
travelguy is offline   Reply With Quote
Old 08-08-2015, 09:46 AM   #32
The chg over for the filter works great I mounted it to a basket like to put weight inside n keep the filter off the ground all is a quick disconnect so it's quick to take apart n thro in basket n done n gives great peace of mind compared to getting a new camper ruined quick good luck also the inside island was mounted wrong when the slide was put I. It would hit the door handles so it got moved 1" in farther
Old 08-08-2015, 05:57 PM   #33
wicked1's Avatar
Originally Posted by travelguy View Post
Hi we have a 2015 Ike's we love it but some issues right from the 1st time we used it the rear in line water filter inside the rear door once hooked up would just spin off n flood everything happened twice an all was on right water is not what u wanna see especially if u are away from your camper an its flooding everything so I took it out n made a box to put it before the I let outside its great no more worries others owners had the same problemAttachment 85129Attachment 85130
I have learned to turn the water and water heater off just not to have issues ever but I check my filter every time I hook up as well.
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 08-08-2015, 06:48 PM   #34
So if I understand things correctly, our filter on our new 2016 IKSS is behind a wood panel that must be removed? Is that correct?
drhroo is offline   Reply With Quote
Old 08-08-2015, 07:44 PM   #35
dudleydoo's Avatar
I just took out the "wood" panel under the bathroom sink. I was able to cut a piece off and also a slot to fit the shower water hose so I could get more floor space. Not too hard to cut with regular household scissors! I may remove that one in the back covering the filter as well.
Bonnie and Rich
Oconomowoc
Winston (Rat Terrier)
Digby (Lhasa Apso)
2014 Shamrock 23IKSS
dudleydoo is offline   Reply With Quote
Old 08-09-2015, 06:48 AM   #36
gbrian0118's Avatar
Not sure with the 16's but with the 15's that is correct. Open the rear compartment, remove the panel directly in front, there are two, and the filter/ pump and the water control valves are located there.
2015 Roo 23IKSS
2016 Silverado 2500HD Duramax
gbrian0118 is offline   Reply With Quote
Old 02-15-2016, 02:09 PM   #37
wicked1's Avatar
When you put a hose where the filter was did you just use the pipe clamps and tighten very well, I figured I would have to use pex piping and buy a pex crimping tool?
2015 Roo 23IKSS
Old 02-15-2016, 02:48 PM   #38
deartruc's Avatar
A pvc pipe coupler easily works to remove your filter and join the pipes together. (the last plastic tab on the canister snaps off which causes the housing to unscrew).
Wicked, you put the filter wrench back on the canister and wedge it in so if the canister was to try to unscrew the wrench would stop it. Could be your secondary line of defense.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 02-15-2016, 04:45 PM   #39
wicked1's Avatar
Ah did not think of the filter housing tool, wedging it could be the answer
2015 Roo 23IKSS
Old 02-15-2016, 10:10 PM   #40
deartruc's Avatar
Needed to do that in order to keep our spring icebreaker trip last year. Was upsetting to flood the trailer twice. I posted a picture of the last tab broken off on the canister which causes it to unscrew.
2017 GMC Yukon
2015 Roo 23 ikss
roo
