Old 02-23-2014, 09:11 AM   #11
Is the hitch 2 5/16"? I forgot to ask before I pick it up. I had a R-Vision hybrid with no leaks and I'm not hearing of any on this new model, so I'm hoping for the best.
kjbpe is offline   Reply With Quote
Old 02-23-2014, 09:18 AM   #12
Ws98ta's Avatar
Thanks for the checklist Triguy.
I do already have a rhino-flex hose from our previous camper.
I normally just use it when at full hook up. I found myself using the cheaper shorter hose while leaving at the dump station instead of dragging out the full length hose.
Also already have a nice drinking/fresh water hose and a regulator.
Thanks for the suggestions! Keep them coming!
2014 roo 23ikss
2014 silverado 1500 4x4 z71
Ws98ta is offline   Reply With Quote
Old 02-23-2014, 11:26 AM   #13
KMP44's Avatar
Yes. Its a 2 5/16" ball.
As for the rear TV outlet, I'm skeptical the back wall is solid enough to hold a TV mount. Its a pretty thin wall between the bunk and the bathroom. If I was going to mount a tv back there, I would use a swivel type arm and mount against the side of the bathroom wardrobe. That way use could use some longer bolts and even put a wood plate inside the wardrobe for extra strength. Then store the tv folded flat against the back wall and pull it out when you use it.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 02-25-2014, 02:06 PM   #14
Does anyone with a 23IKSS know what height to the top of the coupler is when the trailer is level? I'm going to be picking mine up in a couple weeks and want to try to have the hitch close before I get there. Looks like the 233S is ~25" but I'm not sure if this one would be the same. Thanks!
liquidicem is offline   Reply With Quote
Old 02-25-2014, 05:23 PM   #15
Ask dealer to set it up for you the they usually do it for free. Just slide the person doing it a couple bucks. My dealer set up the whole wdh I had. even had to drill new holes for anti sway bar.
CamperCar is offline   Reply With Quote
