Old 03-29-2015, 02:58 PM   #11
bikendan's Avatar
Originally Posted by sewingcybermom View Post
Can you regulate the hot water temp?
the answer is NO. unless you want to do a mod, so you can do that.
i don't know of any hybrid that has that feature, nor a lot of other types of RV's.
nearly all RV's have water heaters with a set temp point.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 03-29-2015, 03:41 PM   #12
bzales's Avatar
Congrats! Happy Camping.
2014 Rockwood Roo 183
2007 Chevy Tahoe LT 4x4
bzales is offline   Reply With Quote
Old 03-29-2015, 04:20 PM   #13
Glindz233s's Avatar
Congrats 1st timer. Enjoy! I like your truck. I'm looking for an upgrade soon and the Chevy/GMC is on the list.
Sewingcybermom - the water heater temp is factory set and you can not change it. I just looked into that as we thought ours was not hot enough. So far we have only run ours on propane but there is an electric switch to run it off campsite electricity (which is recommended so you wont waste your propane).
Happy camping!
Me, Wifey, Thing 1 & 2 plus Gracie the Shitzu rescue
FR Shamrock 233S 2015
2018 Ram 1500 Hemi 5.7 4x4 3.92
Nights Camped: NOT NEARLY ENOUGH!
Glindz233s is offline   Reply With Quote
Old 03-29-2015, 09:55 PM   #14
The Atwood hot water heater owners manual here:
http://manuals.adventurerv.net/Atwoo...er-Service.pdf
says the following (pg 16) under "FEATURES:"
"A pre-set thermostat set for 140 F. An aftermarket retro-fit adjustable thermostat is available and adjustable from 110 to 150 F."
And on pg 23:
"If a customer is dissatisfied with the temperature of the water, first check the water temperature with a cooking thermometer and verifying that the initial cycle is within the time noted above. If not, an adjustable thermostat may be purchased allowing the water temperatures to be adjusted from 110 - 150 F. It fits in place of the original thermostat."
It's not clear if it's talking about the gas thermostat or the 110VAC thermostat, or both.
Looks like about $29 here:
http://www.americanrvcompany.com/Atw...iler-Camper-RV
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 03-29-2015, 10:24 PM   #15
bikendan's Avatar
all Roo/Shamrocks have Surburbans, not Atwoods.
Old 03-29-2015, 10:30 PM   #16
Oops. You're right.
Old 03-30-2015, 07:12 AM   #17
Thanks everyone! First time towing anything this size and this wide! Wow it's wide that God I got trailering mirrors. Nothing like a 12 hour road trip with mountains, cities and caravans of 18 wheelers to get acquainted the handling of the rig. But the equilizer hitch did well. Got her home backed into the driveway in the dark. Here comes one of my 1st questions. ... backing in and weight distribution? I left I hooked up and it was OK but I think I remember seeing a thread that may have selected removing it? But that's for another day. The family is pumped to get out and use it! Now if the weather will just cooperate!
1st timer is offline   Reply With Quote
Old 03-30-2015, 07:32 AM   #18
Certainly feels bigger than it looks here! Lol
Old 03-30-2015, 02:18 PM   #19
bikendan's Avatar
do you have the actual Equal-i-zer or are you using it as a generic term for a WDH? because you said "remove it", makes it sound like you're talking about a single friction anti-sway bar, which the real Equal-i-zer doesn't have.
if it's the real Equal-i-zer, then NO, you don't have to remove the bars.
threads like the one you are thinking about, are referring to old tech WDH's that use a simple added friction anti-sway bar.
Old 03-30-2015, 02:30 PM   #20
Yes it is the real Equal-i-zer, that was going to be a follow up question because it would seem ridiculous to take that apart. I was really impressed with the Equal-i-zer wdh no sway the truck was very calm with 18 wheelers flying by.
23ss
