Old 12-27-2015, 09:21 AM   #11
Originally Posted by BMFLYFISH View Post
My tongue jack has stopped working on my year old 2015 23IKSS and of course I am out of warranty. What have you replaced yours with and are you happy with it?
Just saying the F/R 2nd year Warr.would have cost 150.00$ towards a Replacement jack. Barker Jacks are a Good investment and made in the USA also! Youroo!!
Old 12-27-2015, 10:45 AM   #12
Get a Bulldog, all others are not even in the same class. That's why Bulldog has a 5 yr warranty. Not the cheapest but the best. You get what you don't pay for. Call Rockwood, they may reimburse you at least the cost of the garbage LCI jack that went bad, even after your warranty is expired. Then you can put that towards the new one.
http://www.bulldogproducts.net/products/trailer-jacks/powered-jacks/powered-a-frame-jack-4000-lbs-/USX3uVM!Va4XWXYkPHNidQKvTYX33267HkkoUd16JOE=
Mr Havercamp is offline   Reply With Quote
Old 12-27-2015, 01:04 PM   #13
I recommend the Barker. I had one on my 1998 Sunnybrook. It stopped working after 6 years, sent the head back to Barker they repaired it/replaced it at no charge. I keep a cover on my Hitch Head. Camco makes it, available at most RV stores and Camping World. 2 sizes available, $10.00 to $14.00. Keeps head dry.
tomrob1161 is offline   Reply With Quote
Old 12-27-2015, 02:14 PM   #14
WSY DD693's Avatar
Make sure the jack is grounded good to the frame. That is accomplished by the jack being mounted to the frame with three mounting bolts. After my new jack was installed it did not have a good bond metal to metal from the jack to the frame and sometimes it worked and sometimes not. My first clue was seeing sparks at the frame and mounting bolts and the bottom off the jack was hot. Removing the mounting bolts and scuffing up the mounting flange and frame to get a good (ground) bond did the trick.
2008 Modified Surveyor 303
2010 Dodge Ram Laramie 4x4
2013 From FL to Pick up Surveyor Islip,LI, PA,NY,VT,NH,MA,CT,NY and Home
2014 Sebastian Charleston,SC to Finger Lakes, Lake Erie, Lake Cowanesque,PA and home
2015 Sebastian to PA,NY,WI,MN,return to NY and home
2016 GA,SC,NC,TN,KY,OH,PA,NY,to Sebastian,FL
WSY DD693 is offline   Reply With Quote
Old 12-27-2015, 02:58 PM   #15
Stormrider151's Avatar
When I had my 23ss I had to be careful with how high the jack was on the tongue. Some would not let the front bunk all the way down. I got a Bulldog with a 5 year warranty. It worked very well. The first one stripped a gear and was replaced with no hassles. No problems after that.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 12-27-2015, 03:19 PM   #16
beechjet16mf's Avatar
Trailer Jack
I bought an electric Trailer Jack from Walmart for less than a $100. It installed well and has worked well, and it even has LED light on it for night operations
beechjet16mf is offline   Reply With Quote
Old 12-29-2015, 06:40 PM   #17
pkenley's Avatar
While traveling our quit working...... think DW raised it to high and it locked up. Neighbor with mechanical skills and I took it apart completely taking pics as we went. Put it back together and it has been working for two more years. Take it apart...... nothing to loose when you can have one delivered from Amazon in two days.
Phil & Carla Kenley
2014 Rockwood ROO 21ss
2013 Ford 150 Platinum Crew Cab
(Looking at the Georgetown 329DS)
Nights camped in 2011/16; 2012/15; 2013/48;
2014/10; 2015/101 2016/55 yr to date
pkenley is offline   Reply With Quote
Old 12-29-2015, 07:03 PM   #18
rmac04401's Avatar
New Tongue Jack recommendations
I bought a jack quick 3000 from amazon for around $100.00 for my old 2000 fleetwood that I just upgraded from last August. That jack quick 3000 actually was more sturdy then the one that came within my new 2016 grey wolf. The jack quick Was still going strong after two years before trading up to new toy hauler.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 12-29-2015, 08:20 PM   #19
BMFLYFISH's Avatar
It is actually a switch issue. The jack will lower the tongue but not raise it. I am appreciate all the input. I did not realize tongue jack preference was like a whiskey recommendation.
Thanks Everybody!
Brian
2015 Roo 23IKSS
TV: 2004 GMC Sierra
BMFLYFISH is offline   Reply With Quote
Old 12-29-2015, 09:19 PM   #20
Usually Confused Member
emm-dee's Avatar
It's the same way about most everything that can be replaced or added to an RV. This whole group is a picky bunch.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
