Old 04-04-2016, 09:47 AM   #21
karrun's Avatar
Originally Posted by MuddauberE View Post
2013 Roo 233s Hidden Storage
If the 2015 is like the 2013, then there is some hidden storage in the back I love having.
Hi,
Just checked my 21SS and i have the same! Unfortunately they ran the water and power cords about 4" intot he compartment rather than right against the rear wall, but I think it might still be a good place to store long narrow items like fishing poles, folding camp chairs et.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 04-09-2016, 06:33 AM   #22
Thanks again all. Had another quick question about the slide. Is it okay to use the slide only partially extended? And is it okay to move the camper a few feet with the slide extended.
I only ask because I have it in the driveway and pull it out farther from the garage when I want to open it up. And I was thinking there may be times when the slide can't be fully extended. I recognize it is risky to move with slide extended to avoid hitting things, and I likely never will...but, is it structurally okay just to move the camper a few feet on a level surface while extended?
2015 Shamrock 233S
2007 Expedition EL Eddie Bauer
2015 Shamrock 233S
2007 Ford Expedition EL Eddie Bauer
2016 Nights Camped = 22
2017 Nights Camped = 11
PEAS_PA is offline   Reply With Quote
Old 04-09-2016, 08:14 AM   #23
karrun's Avatar
I wouldn't leave the slide partially extended, and especially not moving it that way. I don't think it's properly supported in that position.
2016 Roo 21SS
Mods so far:
Old 04-09-2016, 08:32 AM   #24
2015 Shamrock 233S
We didn't ask, the dealer specifically told us the slides must be full in or full out in locked position. And the more level the camper, the better. As for moving the unit with the slide extended, that would not be recommended.
With inertia, when you start to move, even slightly, the extended slide will will be slower to respond to movement, thus stressing the mechanism. When stopping, the camper will stop, but the slide will have the tendency to keep moving, again stressing the mechanisms. Then add, any up/down jarring. There is a lot of weight hanging out there and it's not designed to be moving in the extended position. You are taking unnecessary chances in causing damage.
PenJoe is offline   Reply With Quote
Old 04-09-2016, 09:22 AM   #25
Thanks. I expected those answers, but am trying to learn as much as I can about the camper so wanted to ask the question.
2015 Shamrock 233S
Old 04-09-2016, 09:49 AM   #26
SeaDog's Avatar
Hey peas, what others have said is correct something to consider is that if the slide is not all the way out or in then the seals are not sealing so bugs, water, dirt etc will get inside just something to think about
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 04-10-2016, 07:37 AM   #27
Didnt work for me. Sent me to washing machines
tuckerfamily is offline   Reply With Quote
Old 04-10-2016, 07:52 AM   #28
MiCamper6's Avatar
Same here.
MiCamper6 is offline   Reply With Quote
233, 233s, newbie, storage
