Old 08-17-2014, 03:54 PM   #1
No Battery Power in my 23IKSS
For some strange reason I have no power when I use the battery, but when I'm hooked up to 110, everything works great. The hitch works but nothing else. I thought someone mentioned there's a reset switch near the hitch? I don't see anything like that near the hitch. Please tell me this is a quick fix because it's gonna be going to the shop and I hate if it's something like a reset button.
Kyoung is offline   Reply With Quote
Old 08-17-2014, 04:00 PM   #2
is the battery cutoff switch on the lower wall to the left of entrance door pushed in ? If so, pull it out when camping and on battery power and push in while in storage to prevent battery drain.
richl167 is offline   Reply With Quote
Old 08-17-2014, 04:20 PM   #3
I know what you're talking about. Mine is located near the back bunk, near the floor, on the left when your walking in. It's been pulled out the entire time. When it's pushed in, nothing works, not even the slide outs. I'm beginning it must be a little more serious. Do you think the converter might be shot?
Old 08-17-2014, 04:24 PM   #4
fonzie's Avatar
Look underneath the hitch for either a fuse or mini-breaker with small push button on side. either change fuse or push small button. If you have a multimeter check voltage a battery , should be around 12.5 volts.
Fonzie
Old 08-17-2014, 04:44 PM   #5
Yup, I looked under there and I have two fuses and at the time I checked them, they were both good. Do you have a photo of where the reset button underneath is?
Old 08-17-2014, 04:45 PM   #6
When your plugged in and everything works, then your converter is working. It is outputting the 12v you need for those systems.
So, doubt your converter is shot.
It really sounds like Fonzie described, you have a blow fuse/breaker somewhere in the 12v circuit.
Did you look at the converter yet to check for any blown fuses?
Mark B.
2021 GMC 1500
Anderson WDH
markb5900 is offline   Reply With Quote
Old 08-17-2014, 04:51 PM   #7
Bad cutoff switch or maybe if a new unit they never actually connected the battery ?? I'd put a voltmeter on battery terminals to confirm you have a charge. I think the battery will only charge if the cutoff switch is in the connect position ( out) and you are on shore power or connected to tv. if dead you may have to charge a couple of hours before you try battery only power
Old 08-17-2014, 05:05 PM   #8
fonzie's Avatar
No I don't have one for your specific unit, look under trailer near tongue....as shown above.
Fonzie
Old 08-17-2014, 05:12 PM   #9
I checked all the fuses in the converter/fuse box and they were all good. In fact, I doubled checked the two fuses underneath just now and they were both good. I just got back from camping with it this weekend and had to use the generator, and the times I was using it, it did charge the battery, at least that what it read on the control panel display. It read 2/3.
Old 08-17-2014, 05:38 PM   #10
I suppose I should mention that last fall when I was storing it for the winter, I had to back it into a extremely tight spot in a barn and ended up pinching the cord and instead of trying to fix it, I had it replaced by a mechanic. Everything worked great last year and this is the first time I had it out this year. I did open the junction box underneath to make sure everything was connected within the wiring nuts, and it all looked good. Now what?
Old 08-18-2014, 04:57 PM   #11
Could it be the mechanic possibly wired it wrong?
and if so does anyone know where I could find the wiring schematics?
Old 08-18-2014, 05:22 PM   #12
Jimandchris's Avatar
The breaker is the rectangular grey box in the photo, should have a black button on the side. That may need to be reset.
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
Jimandchris is offline   Reply With Quote
Old 08-18-2014, 05:36 PM   #13
I owe you guys big time!! Sure enough i found it. Why do you suppose it tripped? (so I can avoid it in the future) Thanks again to EVERYONE here for helping me.
Kevin
Old 08-18-2014, 05:38 PM   #14
It may have happened when the tech was repairing the cable. At least it was an easy fix for you! They're the best kind.
Old 08-18-2014, 06:58 PM   #15
bikendan's Avatar
It usually happens when someone crosses the battery wires.
battery, power
