Old 09-29-2011, 08:26 PM   #11
TURBS's Avatar
Originally Posted by tmiller View Post
Great! Any idea on the best one to get?
I would double check your voltage and make sure you have no 12 volt output with a volt ohm meter .
here is trouble shooting info for an 8900 series wfco .http://www.wfcoelectronics.com/docum...%20English.pdf
do you have a wfco ? model number ?
look like this ?
Old 09-29-2011, 08:31 PM   #12
Yes it looks like those pics. Not sure of model number. Will look at it in the morning.
tmiller is offline   Reply With Quote
Old 09-29-2011, 08:40 PM   #13
TURBS's Avatar
check the model number then go to You are today’s WINNER! and go under manual for your convertor model and look up testing .
when my wfco convertor went bad i replace just the convertor portion and reused the wfco frame and circuits . I bought a 75 amp convertor from intelli power and installed it in the wfco frame.
I did have to do some mods to get it to fit but was very minor.
I also got the charger wizard for it .
http://www.progressivedyn.com/prod_d...zard_9105.html
http://www.progressivedyn.com/prod_d..._pd9170_2.html
Old 09-29-2011, 08:50 PM   #14
Thanks for all your help
