Old 07-01-2015, 07:28 PM   #1
husky family's Avatar
No power to outlets
Hi everyone. I have a 2014 Roo 233s and started packing it up for a weekend trip. Plugged into shore power, but no power to my outlets. All else seems to be working. Fridge, a/c, microwave, etc. All breakers good, all fuses good. Even checked fuse and breaker under the camper. What am I missing??
2014 Rockwood Roo 233s
2014 Runaway Navigator
2013 GMC Yukon XL
husky family is offline   Reply With Quote
Old 07-01-2015, 07:36 PM   #2
nvychf's Avatar
I would double check your fuses and breakers. I just purchased a 2015 233S, I pick it up Friday. But I do know that our breaker panel under the frig has small LEDs that light up when the fuse is bad, I would check there again.
nvychf is offline   Reply With Quote
Old 07-01-2015, 07:39 PM   #3
crunchman12001's Avatar
Check to see if you tripped a GFI inside.
crunchman
2015 F-250 FX4
Old 07-01-2015, 07:40 PM   #4
The fuses are for 12VDC circuits. I'm assuming the posters issues are with his 110VAC outlets, since the other things he says are working are 110VAC powered. So his issue would be with the circuit breakers.
He needs to check the GFCI in his bathroom. If the GFCI trips, it also kills power in many of the other 110VAC outlets.
2011 Traverse LT, 3.6L, FWD
Old 07-01-2015, 07:49 PM   #5
Thanks guys. It was the GFCI outlet tripped. All good now.
2013 GMC Yukon XL
Old 07-01-2015, 07:52 PM   #6
crunchman
I am in this corner also! Youroo!!
Old 07-01-2015, 07:55 PM   #7
Suggest you go to Lowes/HD and buy new ones to replace the factory ones which are notoriously poor quality.
Old 07-01-2015, 07:56 PM   #8
Excellent, glad we got you going.
happy camping!
crunchman
2015 F-250 FX4
Old 07-01-2015, 08:06 PM   #9
VinceU's Avatar
The red Led light comes when a DC circuit opens. AC circuits all use the handle flip switch, half open is a trip indicator.
Old 07-01-2015, 08:15 PM   #10
nvychf's Avatar
Good to know, did not think the GFCI would be daisy chained together. Thanks Crunch!
Just own it and you will be okay. Just own it.
power, electrical
