Old 07-21-2014, 09:00 AM   #1
No power to slide out
My slideout worked for the first couple of trips and then there was no power. Not sure if anyone else has experienced this. 2013 Rockwood Roo 23ss. I checked the breakers and fuses, assuming it has to be either the switch or motor?
kbaker is offline   Reply With Quote
Old 07-21-2014, 09:04 AM   #2
TURBS's Avatar
Look at your current limiters near your battery.
Most commonly there resetable.
Follow the positive cable off the battery you'll find them.
"sabre owners united!"
turbs
Old 07-21-2014, 09:33 AM   #3
Herk7769's Avatar
There should be a 30 amp fuse near the battery under the frame. It may be in a green fuse holder. Look for something like this:
HAM CALLSIGN - KC3FFW
Old 07-21-2014, 09:55 AM   #4
There may also be very tiny back reset button the box in the picture that has the wires connected to it...
t0rnado is online now   Reply With Quote
Old 07-21-2014, 01:01 PM   #5
bikendan's Avatar
there is a fuse under the slideout, from what i've read.
usually blows when the switch is held on too long.
i've never had mine blow in the 7 1/2 years i've owned my 23SS(knock on wood), so i'm not sure where it's located.
are your lights working off the battery? if so, then the small resettable breaker wouldn't be the issue.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-22-2014, 07:47 AM   #6
It was the 30 amp fuse under the front of the camper. Thank you for all the responses, I had no it was even there.
Old 07-22-2014, 07:49 AM   #7
Herk7769's Avatar
That fuse is a real money maker for the dealerships
Old 07-23-2014, 06:54 PM   #8
CDNWhiskey's Avatar
Think about replacing that with an auto resetting fuse. I did and it saves you grief
CDNWhiskey is offline   Reply With Quote
Old 07-23-2014, 07:41 PM   #9
Jimandchris's Avatar
X2
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
power, slide, slide out
