Old 04-14-2014, 08:08 AM   #1
No pressure to bathroom sink
Just opened up my 2013 23SS for the first time; the dealer winterized it before I purchased in the fall. I hooked up the water and I have hot and cold water pressure in the kitchen sink, outside and inside shower and toilet; but the bathroom sink is barely flowing. The showers and toilet are further down the water lines then the bathroom sink. Not sure if anyone else has run into a similar problem?
Taking it for our maiden voyage next week, hopefully I can find a quick fix.
Thank you
kbaker is offline   Reply With Quote
Old 04-14-2014, 08:17 AM   #2
Thank you
Check for debris in the aerator screen if your valves are in the correct position.
Old 04-14-2014, 08:20 AM   #3
We had a similar problem with our 5er after we purchased it. little to no pressure in back bathroom sink. Turned out that during the manufacturing process the water supply line loaded up with plastic shavings and nearly blocked the screen at the faucet end. Took water supply line off and blew out faucet to remove shavings. Works fine now. May or may not be your problem but just a possibility.
OKI Marine is offline   Reply With Quote
Old 04-14-2014, 08:30 AM   #4
Iggy's Avatar
I had a similar issue and the low flow nozzle was the issue. Replaced with a regular one I had laying around from a old faucet. Now I have full flow.
The old one was a plastic strainer/filter with small holes in it.
Old 04-14-2014, 09:08 AM   #5
KyDan's Avatar
X2 -check this first.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-14-2014, 09:53 AM   #6
Thank you for the tips, I'll let you know how I make out.
Old 04-14-2014, 07:00 PM   #7
It was plastic debris blocking the nozzle/screen; thanks again for the help.
Old 04-15-2014, 11:33 AM   #8
Dave Lyon's Avatar
X2 - I had the same issue.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
pressure, roo
