Old 09-09-2015, 02:06 PM   #11
B and B's Avatar
Originally Posted by WatkinsGlenCamper View Post
I also use a wand, through the toilet bowl, to clean the black tank while emptying it. The last time I did this, I noticed when I got home there wasn't any water in the toilet bowl (as there should be to prevent odors and to help flush waste). I then lifted the flapper and took a look at the black rubber seal, that the flapper sits against, in the toilet bowl and found it wasn't completely seated for a good seal. I reached in and worked the seal back where it belonged. I then added some water to the bowl and the seal now works once again. The seal must have dislodged when hit by the wand while I was cleaning the black tank.
I had the same thing happen last weekend myself at my park model.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 09-09-2015, 02:12 PM   #12
thestrangebrew's Avatar
Wow. I've had my trailer for a year and didn't know to leave a bit of water in the toilet while in storage. I'll have to remember to pour a bit in tonight when I get home.
2014 F-150 SCREW Ecoboost 4x4.
2014 Rockwood Roo 233s GVWR
thestrangebrew is offline   Reply With Quote
Old 09-10-2015, 07:35 AM   #13
Water in Toilet Bowl Use Silicone
A little spray of silicone on the rubber gasket from time to time helps keep the seal fresh. The seal on our houseboat toilet always seems to leak, but the one in our Roo is still holding water after 6 years. Oxidation is what kills rubber, and the water in the bowl and/or silicone help prevent that.
mnoland30 is offline   Reply With Quote
Old 09-10-2015, 07:36 AM   #14
One more question. Whose toothbrush do you use, your DWs or yours?
Old 09-10-2015, 07:49 AM   #15
PhoneDude 8289's Avatar
Before storing the RV for the cold weather of January and February a good cleaning of the toilet seal and a coat of faucet silicone grease seems to do well. Did this for several years on our previous 5r and never a problem holding water.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 09-10-2015, 07:24 PM   #16
Summer2Go
Summer2Go's Avatar
Brand new Roo, and the toilet never holds water. Do I have a warranty issue, or can it be fixed? We don't like the TV bathroom smells. Thought we were using the wrong chemical.
Summer2Go is offline   Reply With Quote
Old 09-10-2015, 10:10 PM   #17
Summer2Go
Summer2Go's Avatar
Sorry, auto correct; RV.
Old 09-11-2015, 06:31 AM   #18
I think the smells are from the lack of a seal from the toilet. The toilet should hold a few inches of water. New trailer, warranty issue I would think. Yes it can and should be fixed.
Joe & Beverly
2014 8289WS lifted
Old 09-13-2015, 06:19 PM   #19
Purdyquibb's Avatar
I can tell you what I did and it worked great for the toilet seal. I just used a standard toilet brush, I opened the valve and worked the seal up and down with the brush while the water was running through it. There should be some standing water in the bowl at all times, Obviously winter calls for the rv anti freeze but something should always be there. If not chances are good your seal will dry out and not hold any water at all. this can also be corrected using the brush. Happy camping.
Purdyquibb is offline   Reply With Quote
Old 09-13-2015, 06:48 PM   #20
I bought a new toilet after mine stopped working. After having it for a couple of months the water started leaking out of the bowl, so I took it back to the dealer I bought the toilet from, they took it in to look at it and charged me $65 to fix it they said it just needed maintenance they gave me a sheet that says( open flash valve stick your finger down the hole and wipe the seal with your finger, to clean it, then take some vaseline and smear it on the seal) Now when I clean the toilet I open the valve and use the brush to clean it and I have not had any problems since.
Ditchdigger is offline   Reply With Quote
