Old 09-13-2015, 07:02 PM   #21
Explorer
Yep you need a little water in the bowl to trap the smell out of the camper.
They make a specialty brush just for cleaning the seal, looks like a bent heavy duty pipe cleaner. I clean it every year in my spring cleaning routine or as needed and then I use O-ring grease.
I do the same thing to the gate valves of the GW and BW.
Campers are fun.....
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 09-14-2015, 10:34 AM   #22
karrun's Avatar
Originally Posted by Ditchdigger View Post
I bought a new toilet after mine stopped working. After having it for a couple of months the water started leaking out of the bowl, so I took it back to the dealer I bought the toilet from, they took it in to look at it and charged me $65 to fix it they said it just needed maintenance they gave me a sheet that says( open flash valve stick your finger down the hole and wipe the seal with your finger, to clean it, then take some vaseline and smear it on the seal) Now when I clean the toilet I open the valve and use the brush to clean it and I have not had any problems since.
I thought you were going to write a bad joke, about the finger and the vaseline.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 09-14-2015, 04:58 PM   #23
That must be a different thread!
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 09-14-2015, 07:48 PM   #24
No it's not a joke, but when they told me I though it was.
Ditchdigger is offline   Reply With Quote
Old 09-23-2015, 07:08 AM   #25
yetavon's Avatar
Our 2015 21DK has the exterior tank flush system...thought it was standard on all of them?
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2017.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 09-23-2015, 07:25 AM   #26
Flybob's Avatar
I would be cautious of using vaseline as it it a petroleum product and could cause damage tot he rubber seal. I think a silicone product made for pool O-rings would be a better choice.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-23-2015, 01:30 PM   #27
urocav2001's Avatar
They make seal coconut oil I believe too?
urocav2001 is offline   Reply With Quote
