Old 09-08-2015, 07:08 PM   #1
No problems till now
We have a 2015 Roo 21Dk. Only got to use it a couple times last summer then had to winterize it. This year it has had lots of use ( 6 outings so far) with no trouble. Till 2 days ago. We were in the Boston area for a week with friends when the toilet stopped holding water after my DH emptied the black tank. He used the long handled wand thru the toilet to clean out the tank as the sensor still said 1/3 full. We had to make trips to the bathhouse. Then the handle on the screen door broke off and we had to force it open with a screwdriver and put duct tape over it so the piece that goes in the hole to keep it closed wouldn't work. So now of course the screen won't stay close. Then when we were setting up at a campground in PA on the way home the over over the cable/satellite hookup on the outside broke off. None of the problems except the toilet are big but all happening at once is strange. As far as the toilet goes we're not sure if it the gasket or something more. As my husband was emptying the tank he saw a piece of white plastic go thru the clear elbow. Anyone have a similar problem with the toilet?
Ncgrandma is offline   Reply With Quote
Old 09-09-2015, 10:31 AM   #2
What do you mean, "the toilet won't hold water"? The bowl or the holding tank won't hold water. I never have standing water in the bowl. Is this supposed to have water in it? My old trailer never had standing water either.
2015 ikss
syogerst is offline   Reply With Quote
Old 09-09-2015, 10:34 AM   #3
karrun's Avatar
I thought you should have a bit of water in the bowl to help seal out odors. Mine always has some water in it, at least a couple of inches.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
karrun is offline   Reply With Quote
Old 09-09-2015, 10:37 AM   #4
2015 ikss
Yes there should be a small amount of water in the toilet. RV toilets (most) do not have a "P" trap like your house that uses water as a gas/odor block from the plumbing, the water does the same for the black water tank. My toilet even has a sticker telling you to pull the handle part way to allow water to enter without opening the dump valve.
limblips is offline   Reply With Quote
Old 09-09-2015, 10:39 AM   #5
I'll give that a try. Never knew anything about this and I've several trailers over the last 12 years. Thanks!
Old 09-09-2015, 10:52 AM   #6
B and B's Avatar
I think the OP is speaking of the dump valve in the toilet itself. That was the white piece of plastic dumped along with waste. Either buy a new toilet or if under warranty they supply a new toilet.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 09-09-2015, 11:39 AM   #7
WatkinsGlenCamper's Avatar
I also use a wand, through the toilet bowl, to clean the black tank while emptying it. The last time I did this, I noticed when I got home there wasn't any water in the toilet bowl (as there should be to prevent odors and to help flush waste). I then lifted the flapper and took a look at the black rubber seal, that the flapper sits against, in the toilet bowl and found it wasn't completely seated for a good seal. I reached in and worked the seal back where it belonged. I then added some water to the bowl and the seal now works once again. The seal must have dislodged when hit by the wand while I was cleaning the black tank.
2013 Micro-Lite 23LB
2016 Ford 4X4 F150
...and 4 Old Wooden Boats (Penn Yans)
https://www.glenphotos.com
WatkinsGlenCamper is offline   Reply With Quote
Old 09-09-2015, 12:05 PM   #8
DK-in-SC's Avatar
Here's the replacement screen door handle. A friend snapped ours off this summer. Fortunately, it is a quick and inexpensive fix. I actually ordered two so I have a spare. I can see it happening again.
Amazon.com: RV Designer E285 Black Screen Door Latch: Automotive
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DH-DW-D3K-DMTTSAP
DK-in-SC is offline   Reply With Quote
Old 09-09-2015, 12:20 PM   #9
Georgia Frog Rally 2018
aceinspp's Avatar
Yes there should be a small amount of water in the bowel after flushing. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 09-09-2015, 02:04 PM   #10
Always keep a small amount of water in the toilet bowl even when in storage.
This keeps the seals from drying out. When I winterize, I put about a cup of RV antifreeze in the toilet bowl. Sometimes, I have had the water seep out. When this happens, I will clean the seals using an old tooth brush. I tie a string to the handle of the tooth brush so that if I have an oops moment and drop the toothbrush, I can retrieve it.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
