05-27-2016, 11:44 AM
No water in hot water heater
At camp now and filled my fresh water tank to full. Went to check water heater and I could hear air pressure but no water came out. I decided to try the city water connection and still no water is in the water heater. Am I missing something? Does propane have to be on to see if the heater has water? I was under the impression the eater heater gets filled first.
Sent from my SAMSUNG-SM-G925A using Tapatalk
2022 F250
2014 Rockwood Roo 233s
05-27-2016, 11:45 AM
2011 Flagstaff 831 RLBSS
05-27-2016, 11:47 AM
Shouldn't be the valves as I've never messed with them before. I've always had hot water when needed prior to this trip.
2022 F250
05-27-2016, 11:54 AM
Do you have any water coming out your taps (hot tap or cold tap)?
05-27-2016, 11:55 AM
Yea good pressure and cold water from all taps and shower. Toilet too.
2022 F250
05-27-2016, 11:59 AM
I would check for a possible kinked line to/from the water heater...and again maybe the valves just to be sure something didn't get turned over the winter.
I would also flip up the Pressure relief valve on the face of the water heater to see if water comes out there. If it does, then it means water is getting into the water heater and pressurized up to the that point. I would check from the hot water outlet going forward.
If not, then you can start backtracking from there, Starting at the cold water inlet to the water heater.
05-27-2016, 12:00 PM
I'll be checking the lines shortly. Pressure relief valve is where I always check to see if water is in.
2022 F250
05-27-2016, 12:04 PM
When did it last have water in it and have you changed anything since then?
If you opened the pressure relief, how long did you wait for water to come out?
Remember, if completely empty it has to put about 6 gallons in the tank to fill.
05-27-2016, 12:06 PM
I used it in February last time. It's been parked since. I'm wondering if my sensors are inaccurate and my fresh water tank isn't full, which would possibly mean the water heater hasn't been filled as well. Like I said, I was under the impression the hot water heater would be filled before the fresh water tank
2022 F250
05-27-2016, 12:08 PM
I let the pressure go all the way out.
2022 F250
05-27-2016, 12:17 PM
The water pump fills the hot water tank from the main tank. How would water get to the hot water tank first?
05-27-2016, 12:18 PM
No idea. I just that's the way it worked. I'll let the pump run a bit and see what happens
Edit: I don't recall having to turn my pump on and run it for a bit before checking the heater in the past though
2022 F250
05-27-2016, 12:25 PM
But... you said you had water coming out the faucets?
When drawing from the fresh water tank, (or hooked to city water) the water system doesn't care if it is supplying water to the water heater or a cold water line.
But without the water heater being full and allowing water to eventually come out the faucet, there are only two ways I know water could come out the hot faucets without the water heater being full... 1. The bypass valves on the water heater are set incorrectly or... 2. The outside shower faucets are both on and the shut-off on the shower head is closed allowing water to flow from one side (cold) to the other. (hot)
05-27-2016, 12:36 PM
Please keep us posted on solution.
Thanks.
We are heading out in a few for the 1st time and I want to make sure we have hot water.
05-27-2016, 12:47 PM
Your last sentence above is a bit confusing to me. If you are filling the fresh water tank, you must turn on the water pump after you've completed the fill and open either the relief valve on the heater or a hot water facet or two in the RV to get the HWH to fill.
If your using water from a city water spicket, you will fill the HWH by opening the relief valve or a hot water facet inside the RV.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
05-27-2016, 02:31 PM
Well it's working after running the pump for a few minutes. Thanks for the replies and help. Weird that I don't recall ever having to run the pump prior to checking if the heater had water. Maybe I've always ran the pump for other reasons and checked the heater after.
2022 F250
05-27-2016, 03:05 PM
Glad you got it operating. Perhaps before you were connected to city water rather than using the fresh water tank. The city water system would then provide the water pressure rather than your water pump. Glad you got it...enjoy the holiday weekend!
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
05-28-2016, 11:52 AM
If I fill my hot water tank from the fresh water tank I have to turn on the pump and fill the tank. It takes a long time to pump 10 gallons.
Bill
09-11-2016, 09:57 AM
My fresh water tank sensor showing full even after draining tank. I know black and Gray tanks are off but fresh has always worked.
09-11-2016, 09:20 PM
Open a hot water tap in the kitchen sink when you turn on the pump. You should hear air moving through until the hot water tank is full at which time water should start to flow. Remember that the water is being pumped from the fresh water tank & then pushed into the water heater as long as the valves haven't been changed. You said that the last time used was February. For many of us in the northern climes our RV's would still be winterized with the valves in the winter position. Then when we dewinterize we have to change the valves back to normal operation.
2014 Chevy Silverado
2011 Rockwood Roo 233S
