Old 06-01-2014, 03:00 PM   #11
AMarrs's Avatar
Taking off the shower head & checking pressure without the head was my next thought. I'll have to wait till the next trip though. I'm home & the Roo is at the campground. I had a similar issue with the bathroom sink right from the start. Water only trickled out - you could barely wash your hands. Unscrewed the fitting on the faucet & found a small plastic fitting. I don't know if it was supposed to be a restrictor or some kind of aereator but it now resides in a kitchen drawer & water pressure in the bathroom sink is now great.
Ann ("Older than springtime, younger than dirt.")
Molly, my rescued cockapoo, who loves camping
2013 Rockwood Roo 21SS
2003 Dodge Durango SXT w/full towing package
AMarrs is offline   Reply With Quote
Old 06-09-2014, 07:12 AM   #12
Dave Lyon's Avatar
Two of my faucetts did the same thing thing, I removed the aerators and found plastic burrs in the screens. Once cleaned out, they've been problem free.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 06-09-2014, 07:21 AM   #13
Ford Idaho's Avatar
Originally Posted by OldCoot View Post
Pull the shower nozzle off the hose, throw the restrictor in the trash and clean the debris out of the nozzle. Remove the hose completely and look for another restrictor where the hose connects to the faucet. Reinstall everything without the restrictors.
Yes.
Old 03-18-2015, 11:05 AM   #14
I'm currently experiencing the same problem. We have been parked for 1 1/2 months with no pressure/water issues. Suddenly the water in the shower was reduced to a trickle. I turned the shower off, then restarted and flow was fine for 5 seconds then back to a trickle. Have replaced the shower head but no change. Checked hose and shower head and all is clear and flow through shower hose is fine without head attached. All other taps work without issues. Checked water pressure and flow and there have been no changes. What is causing the shower flow to be reduced to a trickle?
crackers@sympatico.ca
Crackers27 is offline   Reply With Quote
Old 03-18-2015, 11:09 AM   #15
Disconnect the hose from the shower head and the faucet and look for metal restrictors, throw them in the trash and reassemble.
Old 03-19-2015, 07:26 AM   #16
The only thing in the water system that could have changed is the filter may have become clogged so I replaced the filter and nothing changed. We have a 2104 Georgetown XL. There are no restricters in the lines. If you push the "off" button on the shower head for about 5 seconds, when you release same the flow/pressure is good for another 5 seconds, then back to a trickle. This defys any flow/pressure logic and I'm at a total loss. crackers@sympatico.ca (please do not remove my email address)
Old 03-19-2015, 07:48 AM   #17
Boss Ox & Drovergirl
oxcamper's Avatar
You don't state if the pressure at the sinks is OK. Take off the shower head from the hose and see if you get pressure.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 03-19-2015, 08:16 AM   #18
Suspect you have a defective shower head.
Old 03-19-2015, 08:37 AM   #19
Flybob's Avatar
This is what a restriction somewhere looks manifests itself as ..
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-19-2015, 08:55 AM   #20
As long as there aren't any obstructions in the line, then I would invest in an Oxygenetics shower head. That made a world of difference for us.
drhuggybear is offline   Reply With Quote
pressure, show, shower, water
