Old 05-31-2014, 09:30 PM   #1
AMarrs's Avatar
No water pressure in shower??
Memorial Day Weekend was the 4th trip in the Roo 21SS - 2 trips last fall & now 2 trips this spring. Same campground, same site all 4 trips. No issues with the shower on the previous 3 trips, but when I tried to take a shower on Saturday, there was NO water pressure. The water just sort of trickled out. I had a really hard time getting my hair wet enough to shampoo - and then rinse out the shampoo. I thought it might be because the campground was full and a lot of other campers were probably taking showers around the same time. (The campground gets water from their own well rather than city water.) And then I thought that maybe I didn't turn the water hookup on as much as I did previously. So I turned up the water - no difference. And when the campground started to empty out - still no difference. I didn't notice any reduction in water pressure in either sink, so the problem seems to be just in the shower. Could it be an issue with the shower head? I seem to remember several people mentioning changing out the shower head in some other threads. Any suggestions?
Ann ("Older than springtime, younger than dirt.")
Molly, my rescued cockapoo, who loves camping
2013 Rockwood Roo 21SS
2003 Dodge Durango SXT w/full towing package
AMarrs is offline   Reply With Quote
Old 05-31-2014, 09:47 PM   #2
BamaBob's Avatar
Check out the oxygenics thread
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 05-31-2014, 10:12 PM   #3
Are you using a pressure regulator? Maybe something's wrong with it.
2011 Traverse LT, 3.6L, FWD
Old 05-31-2014, 10:15 PM   #4
EnduroRdr's Avatar
I had a similar problem about 2 years ago, turns out my anode on hot water heater crumbled and plugged the shower head also plugged up the toilet inlet. Had to take every thing apart and clean out the white flakey junk. I have now elected to not use anodes any longer. I just drain the system in winter and it gets used enough during summer that it gets flushed regular.
2011 Work & Play 27UL and 2006 Dodge Ram 2500 5.9 Cummins.
EnduroRdr is offline   Reply With Quote
Old 05-31-2014, 10:27 PM   #5
AMarrs's Avatar
I don't use a regulator & I replaced the anode at the start of the season. Last trip was less than a month earlier & the water pressure was fine. Nothing was different - the camper hadn't even been moved. (I disconnected everything when we left so the camper could be moved, but they didn't need the site so it sat in the same place.)
I like the sound of the Oxygenics Body Spa RV model. All the reviews are glowing. Think I'll probably give that a try.
Old 06-01-2014, 12:03 AM   #6
Grizzlygibbs's Avatar
Not sure of this is the case but there is a button on the shower head that is supposed to be a shut off to allow you to save water without having to shut off the valves. Could this have been pushed in and you did not notice? Mine used to trickle before I got the oxygenetics.
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
Old 06-01-2014, 02:10 PM   #7
AMarrs's Avatar
It does have a shutoff button on the side of the handle. One way is off & the other is on. Pushed it back & forth several times. Since water still trickles out even when the button is in the "off" position, it was hard to tell on from off!
It's just so weird that it worked fine a month ago and nothing was different.
Old 06-01-2014, 02:18 PM   #8
Steeljag's Avatar
If pressure is good at the sinks, there is a good chance something is clogging the shower head. Can you remove the shower head and test water coming out of shower hose?
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is online now   Reply With Quote
Old 06-01-2014, 02:53 PM   #9
Pull the shower nozzle off the hose, throw the restrictor in the trash and clean the debris out of the nozzle. Remove the hose completely and look for another restrictor where the hose connects to the faucet. Reinstall everything without the restrictors.
Old 06-01-2014, 02:55 PM   #10
Denver, CO
garbonz's Avatar
X2
2017 Fuse 23T
pressure, show, shower, water
