Old 08-23-2012, 11:08 AM   #1
Zsnake's Avatar
Of Chocks and Blocks
Hi All,
I got two questions.
First off, I have observed (and followed like a lemming) people have their stabilizers resting on large wooden blocks. Someone told me that this is because that places less stress on the sissors jack. I say, Bull. If the company that made the camper thought that you would need to shorten the distance between jack and ground they would have supplied blocks of some sort. I think that it is just more convenient to jack up and down six inches than the whole 18 (or whatever) to the ground.
Am I correct?
Second, I have observed campers that stay year after year in the same spot with chocks in front of and behind the wheels. Now, bear in mind, this is on units that have their stabilizers down. What are the chances of a camper rolling out of place with the stabilizers down?
Just asking. :-)
Zsnake is offline   Reply With Quote
Old 08-23-2012, 11:44 AM   #2
Experienced Newbie
I have the yellow legos under each stabilizing jack to reduce the distance I have to crank. A pleasant side effect is reduced (perceived) wiggle in the camper. A smaller "lever" moves less.
I chock my wheels front and back not only to reduce the chance of the trailer "rolling away" but to limit the forward and back movement leading to the above wiggle. I back the trailer into place, then move up a few inches and then back the trailer onto the chocks, then chock in front. Puts tension on both limiting the movement.
2011 Silverado CC/SB
2014 Cougar 31SQB
mhartzel is offline   Reply With Quote
Old 08-23-2012, 11:51 AM   #3
Originally Posted by Zsnake View Post
Hi All,
Am I correct?
Just asking. :-)
Don't use blocks unless the jacks won't reach the ground and never use chocks on the ground. I use the Bal X Chocks that lock between and on the tires. Also use stab jacks that are bolted to the tube in front of the axles to minimize any movement. This is in additon to the homemade stabilizers going from the frame on one side to the jack pad on the opposite side. Stops all movement.
Old 08-23-2012, 11:53 AM   #4
Gjfournier48's Avatar
Hello,
I place 4"x4" blocking and a 1'x1'x3/4" piece of plywood under all of my jacks to help prevent them from sinking into the ground. It has nothing to do with the amount I have to crank it down.
The wheel chocks in front/behind the tire is a safety feature. Once the camper is stabilized, there still could be slight movement, which in turn could bend your stabilizers, if you don't have wheel chocks. I use X-Chocks and love them.
Gjfournier48 is offline   Reply With Quote
Old 08-23-2012, 12:03 PM   #5
The further you extend your scissor jacks the less stable they become. In my experience it helps to place blocks under them to shorten how far they're extended and provide more strength.
Len & Cheri is offline   Reply With Quote
Old 08-23-2012, 12:04 PM   #6
TURBS's Avatar
X2
Old 08-23-2012, 12:25 PM   #7
Rugged Brown's Avatar
It's all about reducing the distance to lower the jacks for me. Nothing more, nothing less.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 08-23-2012, 01:59 PM   #8
Zsnake's Avatar
Thanks all for your input. Never thought of the chocks affecting the stability of the camper.
Old 08-23-2012, 03:20 PM   #9
Alleged curmudgeon
Vern's Avatar
Seems pretty obvious to me that the stabilizer jacks have a better base (more stable) when NOT fully extended, so I use a 6x6 under each.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 08-23-2012, 03:54 PM   #10
Camper Less Camping
Cajun Po-Boy's Avatar
Ditto
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
expandable, hybrid, shamrock
