Old 07-07-2015, 07:20 AM   #21
Georgia Frog Rally 2018
aceinspp's Avatar
What I have found with my new camper is that the lowest setting for volume (1) is way to loud. Something amiss here but I can deal with it. Usually I'm the one that listens to the radio out side. So I turn the A & B off for inside as the wife maybe watching TV or reading a book. If I want to listen inside I use the bed room speaker as the one in the main area is to loud on it's lowest setting. BTW anybody know how to remove the radio? Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-07-2015, 07:26 AM   #22
Evereddie's Avatar
Is it too loud on all inputs? Is FM radio loud, is DVD loud, is the TV loud? That is weird. Remove radio: What kind of radio is it?
Evereddie is online now   Reply With Quote
Old 07-07-2015, 11:14 AM   #23
urocav2001's Avatar
My new unit has an irv brand unit. It's wired a inside right b inside left and c both outside but you can go into the settings and change the balance to only right or left speaker only, only complaint is that when you turn the unit off and back on again it turns all three channels on no matter what and the volume stays where you set it when you turned it off. Trying to look into this on why it does this..
urocav2001 is offline   Reply With Quote
Old 07-07-2015, 11:39 AM   #24
Evereddie's Avatar
My Genesis turns all the speakers on too. I have to remember to turn off outside or the neighbors get drenched in our sound.
Old 07-07-2015, 12:10 PM   #25
Old Ram Guy
Avenger61's Avatar
I have the same problem with the speakers but I did replace the thermostat with this digital thermostat and it was a wire for wire replacement. Took about 15 minutes:
Robot Check
Marty, Jenice and DD
Avenger61 is offline   Reply With Quote
Old 07-07-2015, 01:01 PM   #26
Evereddie's Avatar
Robot Check
I did the exact same mod. Love it.
Old 07-10-2015, 10:05 AM   #27
Pockets
I usually turn off A and crank the volume for C while I cook in the outdoor kitchen
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg
2015(36 nights) 2016(74 nights) 2017(174) 2018(105 nights)
Pockets is offline   Reply With Quote
Old 07-10-2015, 03:11 PM   #28
deartruc's Avatar
Originally Posted by Toddavid View Post
And another question for now: has anyone installed an inline volume control for the outside speakers? To hear them properly outside means someone going deaf inside.
Todd
I found that FR had wired both (A) left and (B) left to the inside spekers. Since the radio has no fader you would use the Balance control to psuedo fade. Not stereo for sure. I posted what I did here:
Genesis gt 2.0 mods
The sub is phenomenal. But it does make my keyrack mod jingle at volume...
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
thermostat
