Old 08-05-2015, 02:44 PM   #31
Marines0811's Avatar
Moved them back to 30" that's what my instructions say. Then move Like L bracket up 2 holes. Measured on a flat surface back wheelwell 39 1/4" unhooked 38 1/4" hooked. Front 36 1/2" unhooked 36 3/4" hooked . Seems easier when pulling now. Will weigh it again before heading out to Mount Rushmore in 2 weeks.
Marines0811 is offline   Reply With Quote
Old 08-05-2015, 02:45 PM   #32
Pictures
ID:	84989   Click image for larger version
ID:	84990   Click image for larger version
ID:	84991   Click image for larger version
Old 08-05-2015, 03:09 PM   #33
Tonkatoy77's Avatar
Your wheel well measurements sound to be pretty good. But I would drop the L brackets down one hole and add washers to your hitch head to tilt it down. Your L brackets should be at 32" from the hitch if possible. Less than 32" if needed. How many washers do you have on your hitch head now? equalizer recommends using 4 to start with. These are the washers I am talking about.
2007 Chevy Duramax EFI Live and other supporting mods.
2015 Wildcat Maxx T26BHS
Nights camped 2015....23
Tonkatoy77 is offline   Reply With Quote
Old 08-05-2015, 03:32 PM   #34
5 washers. My instructions say 30"
Old 08-05-2015, 03:50 PM   #35
Tonkatoy77's Avatar
If yours is a 12000 pound Equalizer, your instructions should look like the ones on post #28. It is what my 12000 pound hitch came with.
Old 08-05-2015, 03:53 PM   #36
Tonkatoy77's Avatar
I just noticed yours is an E2. Mine is an E4, that might be the difference.
Old 08-05-2015, 04:33 PM   #37
Pretty much the same installation instructions for both of those.
One word of warning! Go easy and do NOT over torque the nuts holding on the L brackets of an E2. Don't ask me how I know and heed this warning
madmaxmutt is offline   Reply With Quote
weight
