Old 08-01-2015, 10:09 AM   #1
Marines0811's Avatar
OK weight police
OK let me know how I am doing. This was fully loaded with gas and propane,, etc. But just me not my 3 kids and wife. The extra 200lbs is me stepping on the scale the last 2 times.
ID:	84724   Click image for larger version
ID:	84725   Click image for larger version
Marines0811 is offline   Reply With Quote
Old 08-04-2015, 02:01 PM   #2
You have to weight more than that to figure everything out. You need to weigh the whole rig like you did. Then take off WDH bars weigh again and then just weigh the truck. With those 3 weigh tickets you can figure tounge weight, trailer weight etc... I did the same thing as you, my big concern was how much weight was on the double axle. SOme day I will weigh everything correctly
2008 F150 v8 5.4
2015Rockwood Roo 23SS
2015 Nights Camping: 39
2016 Reserved: 23
Davylee is offline   Reply With Quote
Old 08-04-2015, 03:59 PM   #3
You also didn't say what your TV was, or any of the specs on it. So no one can really pass judgement. (Well, they CAN, but they shouldn't )
2011 Traverse LT, 3.6L, FWD
Old 08-04-2015, 04:19 PM   #4
prof_fate's Avatar
at least need to weigh the truck alone. can probably deduce the toungue weight that way, and what weight is being moved to the front axle with the bars.
or is this a 5vr?
As rockfordroo says - need more info.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 08-04-2015, 04:49 PM   #5
Weight it 3 different times. Once all hooked up with WDH, once unhooked and once hooked without WDH
Old 08-04-2015, 04:50 PM   #6
MtnGuy's Avatar
The OP needs to explain what is going on with each weight sheet. Trailer hooked up, unhooked, bars attached, not attached. Need more information than just showing the weight sheets.
Old 08-04-2015, 05:13 PM   #7
1st one is hooked up WITH WDH
2nd is trailer not hooked to truck
3rd is hooked without WDH
Old 08-04-2015, 05:14 PM   #8
Went to your profile and saw your rv and tv. Similar to mine ( I have a 23ikss) You should be well within the tv capabilities and have no problems. We've pulled ours through the hills of southern Indiana on narrow county roads and also crowded interstates. Plenty of power, plenty of brake, and a smooth ride. 9-11 mpg
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 08-04-2015, 05:31 PM   #9
Same MPG pulled mine 6 hours to Grand Forks, ND. Got 11.5 up and 10 back
Old 08-04-2015, 05:51 PM   #10
Oaklevel's Avatar
Did you unhook the trailer while on the scales?? If so please do not do that. Take it to the lot unhook & weigh the truck alone...... If a trucker is waiting you may have an issue.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
weight
