Old 05-22-2015, 01:56 PM   #1
OMG Scissor Jack Question
New to scissor jacks on my camper. The first three had outrigger jacks and
never had a problem. After leveling the camper, I just tightened them down as hard as I could, and had no problem.
Now with scissor jacks I am having a problem. I level up the camper and when I extend the jacks, they seem to be too aggressive. When I think I am
done, I've noticed that sometimes the tongue jack lifts up about 1/4" or more, and the door does not fasten good. When I raise all the jacks, the camper is level and the door works great.
My question is, do you just lightly place the jacks on the ground, and call it
good? And then go around later and maybe tighten them a little more?
Any advice would be great.
dogevans is offline   Reply With Quote
Old 05-22-2015, 02:04 PM   #2
I put mine down snug but not overly hard. I then tighten them again a little the next day.
Patrick & Cecilia
2012 GMC Sierra 2500 HD Crewcab Duramax
2014 Forest River Tracer 2750 RBS
Honda eu3000 Generator
2015 Nights Camped : 37
2014 Nights Camped : 33
Quasipato is offline   Reply With Quote
Old 05-22-2015, 02:24 PM   #3
KMP44's Avatar
Its very easy to over-tighten these jacks, and your first clue is the door not shutting properly. They should be snug, but you can't take all the movement out of the trailer with the jacks. X-chocks and other stabilizing systems can help stabilize the trailer more.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 05-22-2015, 02:44 PM   #4
I just run them down snug on the ground, mine are for stabilizing and I do not list with them. I sung em up and then go inside and kinda rock back and forth a tad (nothing crazy) then go back and snug em up again.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 05-22-2015, 03:17 PM   #5
RooVader's Avatar
I like to use the plastic blocks so I don't have to extend them as far. In my experience they tend to do a little better when they are against something solid and not as extended.
RooVader is offline   Reply With Quote
Old 05-22-2015, 05:16 PM   #6
I run mine down with a cordless drill. It's got a torque setting ring, so I can adjust how snug they are with the torque ring. Start light and work up.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 05-22-2015, 07:51 PM   #7
If you are lifting the trailer, that is a major problem. They are only supposed to touch the ground to avoid shaking when moving about. They are not for support. I use an 18v cordless drill and high slip setting to run them down until they just touch.
richl167 is offline   Reply With Quote
Old 05-24-2015, 08:45 AM   #8
You beat me to it. Only to be used for stabilizing the trailer, not leveling it.
Harbor Freight has an 18 volt 1/4 inch impact that works great for running them in and out. Seems to have just the right amount of torque.
JIM
oldtool2 is offline   Reply With Quote
Old 05-25-2015, 06:43 AM   #9
Dave Lyon's Avatar
JIM
X3. I use Lynx levellers to shorten up the depth on the scissor jack and adjust them every day.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 05-25-2015, 07:32 AM   #10
wicked1's Avatar
I got this pair for the RV works perfect then all you need is the socket
Name:	ImageUploadedByForest River Forums1432557176.837201.jpg
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
