Old 10-04-2015, 10:11 AM   #41
Who Dares, Wins
doc73's Avatar
Originally Posted by BillyBass View Post
No body answer my question.are you saying I can use the build in pump to fill my fw thru the af line.
You can if you read above. I did answer how I do it. You use the pump to suck the water into the trailer. From here you can run the trailer by using the water jug as your fw tank. Or if you have an outside shower close you put the hose into the fill and I use the pump to suck the water then pump it out the shower hose into the fw tank.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 10-04-2015, 10:28 AM   #42
Future Roo 23IKSS Owner
elundquist's Avatar
You can use the existing pump to fill the water pipes from the antifreeze port. But to fill the fresh water tank you need to then use a water source on the camper to fill the FW tank. You could use the outside shower or run a hide from a fixture.
I installed a new water line from an existing cold water line to the tank. The new line has a ball valve to control the water fill.
Erik Lundquist
iPhone 6S using Tapatalk
elundquist is offline   Reply With Quote
camping, dry camping
