Old 04-06-2016, 01:04 PM   #1
operating slides on just TV power
Good Afternoon all,
Do I need to bring the battery out to the camper to open up the slides or can I plug in my truck and operate off the truck power. I have a 2014 Roo IKSS.
The main reason is I am in the middle of a bit of health issue and cannot lift the battery at this time.
I am meeting someone out at the storage place who is interested in purchasing the rig. If I can't just power up from the TV I will need to reschedule when I can have someone come with me to install the battery.
Thanks for the help.
Greg
Curry's
2014 ROO 24 IKSS
2012 F150 Quad Cab Eco Boost short bed w/tow package
fyrdad is offline   Reply With Quote
Old 04-06-2016, 01:26 PM   #2
Broken Toe
Cowracer's Avatar
I am pretty sure you need the battery. The wires in the 7 pin aren't big enough.
Worse come to worse, can you use a jumper box or jumper cables from your vehicle to the battery connections on the trailer. That should be plenty.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 04-06-2016, 01:29 PM   #3
Thanks Cowracer, I have a heavy set of jumper cables that I always carry. I'll give that a try if it doesn't work.
Curry's
2014 ROO 24 IKSS
Old 04-06-2016, 01:35 PM   #4
dieselguy's Avatar
It can be done, but I wouldn't recommend it. That little 14 gauge wire on your TV will get a bit HOT trying to feed 60 - 80 amps if you are talking a hydraulic slide motor. Like suggested jumper cables hooked to a battery would be a better choice.
dieselguy is offline   Reply With Quote
Old 04-06-2016, 01:42 PM   #5
bikendan's Avatar
Very few owners realize how little juice most tow vehicles provide.
Vast majority only provide a trickle charge through the cord.
Agree that jumper cables are better.
Old 04-06-2016, 03:03 PM   #6
A light weight portable emergency starting pack will definitely work. Our dealer used one to show us all of their display models when we purchased. Jumper cables to your truck should be fine if you don't have a starting pack.
HTH
Stu
Stu
Calgary AB
2014 Roo 233S
2011 Ford Econoline Club Wagon
stugilmour is offline   Reply With Quote
Old 04-07-2016, 01:40 PM   #7
Tom48's Avatar
On mine I blew the line fuse to the seven pin with a lot less than a slide motor. Then didn't catch it until I arrived in camp with half dead battery.
Tom48 is offline   Reply With Quote
Old 04-07-2016, 01:57 PM   #8
RACarvalho's Avatar
I'm not sure what "pin" the slide motors would be drawing power from but I'm sure my pin number 7 (brake) has a 30A fuse on it...
This means 360W max. which is nothing for a slide motor.
The jumper cables with the engine running would work but personally I think that bring the battery is the lowest risk path...
2018 F150 XLT V8 HDPP
2018 Rockwood 2909WS
" Life is simpler when you plow around the stump..."
RACarvalho is offline   Reply With Quote
Old 04-07-2016, 06:55 PM   #9
I have the same trailer. You will need the battery or jumper cables. Been there done that. Couldn't get slides to move from 7-pin tv.. Thought fuse was blown but not enough power .
JWHybrid2B is offline   Reply With Quote
power, slide, slide out
