Old 05-18-2015, 01:23 PM   #11
Maris's Avatar
We had a Shamrock as well & stored the BBQ & table in the truck box. Our 2009 table was laminated & we left it out in the rain one night. It didn't do well. We only used the BBQ once when our son borrowed our portable Napoleon BBQ. It worked fine but as stated before we didn't want to BBQ so close to the trailer and the bracket for mounting was high. In the newer Rockwoods the table is plastic & should stand up.
Maris is offline   Reply With Quote
Old 05-18-2015, 02:26 PM   #12
wicked1's Avatar
I store the table under my couch in the drawer but carry the grill in my pickup bed don't want it flying around the inside of my Roo or gouging my shower tray
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 05-18-2015, 02:31 PM   #13
Old Ram Guy
Avenger61's Avatar
We got one of these a few weeks ago:
http://www.campingworld.com/shopping...er-grill/69323
Works great with the onboard propane connection. I got a little camping table to set it on and just removed the swing out arm that held the cheap grill that came with the camper.
Marty, Jenice and DD
Avenger61 is offline   Reply With Quote
Old 05-18-2015, 02:53 PM   #14
I have the outside grill purchased with my 2016 Rockwood. It is new in the box and I don't intend to use it. I just wanted the installed gas plumbing. I'd be willing to sell it if you're interested. Does your camper have the gas connection? It is not like what used to come on the Fleetwood popups. Those were high pressure lines (tank pressure). The Forest River trailers use low pressure (after the regulator) gas plumbing which means that anything that you want to connect must work on low pressure.
hunterrick is offline   Reply With Quote
Old 05-18-2015, 07:18 PM   #15
Thank you all for the replies and information. What we were really looking for in the outside grill is a high pressure grill like the one we had on our pop up. It sounds like the Rockwood grills are not the same; we already have a regular propane grill that we can use. We do have the gas connection, if our grill doesn't run off that we might be looking for another one.
Although we have had a pop up for years, I have come to realize that we really are newbies in the trailer world. I'm so happy that I found these boards; I'm sure that we will have many questions after we camp this weekend.
sshea13 is offline   Reply With Quote
Old 05-18-2015, 08:26 PM   #16
If the one on your pop-up ran off the gas bottle on the pop-up then it most likely was a low pressure grill, not high pressure.
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 05-19-2015, 06:37 AM   #17
The grill on our pop up ran off the gas connection and was definitely a high pressure grill. I loved it for boiling water - so quick! Our portable gas grill runs off a propane tank; I'm guessing that means that it is low pressure and can hook to the gas connection on our Roo?
Old 05-19-2015, 06:46 AM   #18
Did it run off the gas connection on the pop-up itself? If so, I would have thought it would have been after the regulator, which would make it a low pressure. I definitely could be mistaken, but that is how I understand the propane system to work.
When you say your portable runs off a propane tank, are you talking about the little green screw in cylinders? Or a larger 20LB tank that has a hose running from it to the grill?
2016 Flagstaff 23LB
Old 05-19-2015, 06:47 AM   #19
TURBS's Avatar
Your grill on your pop up shouldn't have or technically couldn't be high pressure.
Your pop up had a regulator right on the tank.
Only way to be high pressure is to hook it directly to the tank.
The portable you ran right off the tank is probably regulated in side the grill.
I'm not sure I've ever seen a high pressure grill ever.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "6 nights"
Old 05-19-2015, 07:33 AM   #20
We bought our 2013 Roo 23SS used last fall. We have the table that attaches outside, but no grill. Is there anywhere that you can purchase equipment like that? We had a Coleman/Fleetwood pop-up prior to this and it was easy to get extra parts and equipment, but I haven't been able to find anything for Roos.
I guess another good question would be how does this outdoor grill work? Is it even worth trying to find? We used the one on our pop-up all the time; although we do also bring a small gas grill with us for actually grilling.
My 2005 had one and I used it all the time. My 2008 had the mount but no grill or gas line so the dealer gave me a 20 pound tank and gas line. It was cheaper for him than to add the gas line that was missing. On the 5th wheel Rockwood it was an add on.
I would rather use it or the microwave than heat up the trailer. Why not use a 2 burner Colman on a small aluminum table?
Jim D
oldtool2 is offline   Reply With Quote
23ss, roo
