Old 01-08-2015, 10:29 PM   #1
Outside tv mount
Do you know if the tv inside the camper easily comes off to go on the outside tv mount? My husband says no and must be taken off w/ tools. I looked and didn't see where it would slide up. Seems like it should come off somehow and placed outside on the mount.
We are using stock tv/mount inside the camper.
2014 Rockwood Roo 233S
2013 Toyota Tundra 5.8L V8 Crewmax
2 girls and 2 dogs
ParrishCamper is offline   Reply With Quote
Old 01-09-2015, 03:43 AM   #2
searay245se's Avatar
Mine from the inside slides right up and off and then slides down on the bedroom mount or outside mount.
Jeff & Debbie
2015 Tracer Air 255
2015 Ram Laramie Power Wagon 2500
searay245se is offline   Reply With Quote
Old 01-09-2015, 06:04 AM   #3
Oaklevel's Avatar
Ours does the same it slides up off the inside mount and onto the outside mount (at the wall) . When off our inside mount looks similar to the outside mount. I assume if you have an outside mount yours will either work the same way or another TV mount should have come with the camper.
I didn't think ours did it that way at first but it does.
Or it might not.................
Good Luck !!!!
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Oaklevel is online now   Reply With Quote
Old 01-09-2015, 06:19 AM   #4
You'll need to pull the tv from the wall more than half of the travel of the extension arm. Then you'll be able to push up on the base of the mount and the mount will come off. The mount won't come off for safety reasons unless the mount is extended.
2014 Roo 21DK
2015 F150
ChibullsAN is online now   Reply With Quote
Old 01-09-2015, 06:58 AM   #5
KDHfan's Avatar
Outside tv mount
If there are mounts outside and in, it certainly should pop out and interchange easily. That's the point. I had one that you just slide up and out... And I had another that you had to push in a locking mechanism before lifting it up out.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 01-09-2015, 10:33 AM   #6
rsdata's Avatar
Does anyone have a source for the tv mount used in late model Roo Shamrock?
2014 Shamrock 183
2014 RAM 1500 SLT Crew Cab HEMI 3.21 8 Spd 4X4
Old 01-10-2015, 08:14 AM   #7
DK-in-SC's Avatar
As others have said, if you have the mount on the outside of your camper, you can pop the bracket off the inside mount and connect it outside. That was the easy part.
What I found a pain were the wires. Problem 1: The cable jacks all over my camper are the screw on type. But for some reason the cable jack by the exterior TV mount is not a screw on but rather a push on. So the cable wire wouldn't work and I had to get a new push on wire. Not a big deal but I didn't realize it until we were already at camp and actually tried to watch tv outside.
Problem 2: I found that getting the TV power cord out of the entertainment console was easy. But trying to get it back routed thru the holes was impossible and I had to pull out the Genesis stereo console to have access to get the wire back. So I found a short 3 prong extension cord on Amazon that is now permanently run in the entertainment console so I won't have to fish wires any more.
I live with fear every day, and sometimes she lets me go fishing.
2015 Shamrock 23IKSS
2008 Ford Expedition EL
DK-in-SC is offline   Reply With Quote
Old 01-10-2015, 08:22 AM   #8
camper1999's Avatar
Not really related to this topic but I did not want to keep moving the TV in and out so I added a TV that tucks away in the storage area
ID:	68283   Click image for larger version
ID:	68284   Click image for larger version
2011 GMC 2500HD Diesel
mount, tv mount
