Old 05-13-2014, 10:08 PM   #1
Oven lighting
I went to light the oven and couldn't figure out where to hold the lighter flame, any idea? 2014 21S Roo oven.
jnbwest97 is offline   Reply With Quote
Old 05-13-2014, 11:48 PM   #2
Grizzlygibbs's Avatar
Mine is a PITA to get lit. We have only used it once and it was my wife's patience that got it going. I wished I would have opted for more cabinet space. I believe you hold the lighter near the pilot light toward the back of the oven.
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
Old 05-14-2014, 12:36 AM   #3
Velosprout's Avatar
I have only had our new camper out on two trips and used the oven already for two cakes, biscuits, and baked potatoes. It does a great job. The flame is held at the rear of the burner where there are two small projections about the size of a ink pen's inner refill. The bottom projection emits the flame and the top one is the thermocouple which heats from the pilot light and tells the gas control to keep the pilot on and allow the main gas to flow when the temperature knob is turned up.
Before lighting, run the burners on the stovetop to get any air out of the gas lines. After you get it lit the first time, you will find it quick and efficient to get going. Run the oven for the first time without any plans to cook and with plenty of ventilation as there is odor from the initial heating of the oven burning off any manufacturing residues.
Enjoy!
Velosprout
2014 F150 SCrew 4x4 Max Tow Heavy Duty Payload 3.5 Ecoboost 6.5' bed Ingot Metallic Silver
2015 Rockwood Roo 21SS
Velosprout is offline   Reply With Quote
Old 05-14-2014, 04:17 AM   #4
Although I haven't tried this, it sounds like a great idea to make lighting the pilot easier. Hot melt glue a tea candle to a paint stir stick. Light the candle and use it to light the pilot.
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 05-14-2014, 05:45 AM   #5
fonzie's Avatar
Here is YouTube video, not the best but it gets job done.
Fonzie
Old 05-14-2014, 07:44 AM   #6
RedStick's Avatar
Oven lighting
We utilized a tip that I read on the forum by placing tin foil underneath the pan/baking sheet so that the bottom of the biscuits or cinnamon rolls - or my favorite - cookies - aren't overcooked.
The oven certainly does the job and is a nice luxury to have for us while "camping".
As stated above the key is to get the air out of the gas lines first. Ours lights just fine afterwards. A small learning curve as it took me about 15 - 20 minutes the first go-round lighting that bad boy.
Good luck!
2013 Rockwood Roo 23ss
2012 F150 Ecoboost
Camped for 12 nights in 2015 - too many cancellations
Camped for 25 nights in 2014!
Camped for 24 nights in 2013!
RedStick is offline   Reply With Quote
Old 05-14-2014, 07:51 AM   #7
KyDan's Avatar
Try a long nose butane lighter. About a buck at the dollar store.
No wax to drip and it lights itself. A candle still needs to be lit by something
else.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-14-2014, 07:55 AM   #8
I use one of those long handled lighters that are about a foot long. Just turn the oven knob to pilot, press on the knob and move the lighter around under the oven burner. Sooner or later you will get it in the right spot and it will ignite. Hold the knob in for a few seconds and release. If the pilot goes out you will have to repeat.
comfun1 is offline   Reply With Quote
Old 05-14-2014, 07:59 AM   #9
Among our camping friends we are the only ones that use the oven. We also have a tile in the bottom to maintain a more even heat and we use an oven thermometer so we can more accurately monitor the oven temperature.
Old 05-14-2014, 08:10 AM   #10
MC9
Got to admit the ovens on all the rvs we've owned have been a problem (too far back, not enough room for your hand, etc.) Went to Home Depot and purchased a BBQ lighter and installed same. I should have gotten 4-way for all the burners.
MC9 is offline   Reply With Quote
light
