Old 09-08-2013, 10:53 AM   #1
Oven pilot
Oven pilot stays lit until oven reaches temp. Then when gas turns off (at temp.) pilot goes off too. It is a 2014 23iks
CamperCar is offline   Reply With Quote
Old 09-08-2013, 12:43 PM   #2
kc8lvy's Avatar
Mine was doing the same thing and I searched many forums and read lots of things it could be then I read on 1 of the forums that there is a small hole on the back side of the pilot light for air mixture and they suggested that you wrap a small piece of aluminum foil around it and don't cover it all the way just enough to block a little air. I tried it and it worked but I thought that the foil would fall off or move and I would always be messing with it. So I went and bought the smallest hose clamp I could find and put around it. It can still get air and I tried it twice and it stayed lit. We went camping and we baked in it 2 more times and it still stays lit.
My brothers 2003 Coachman oven did the same thing and he ended up taking it to the dealer 3 or 4 times and they finally replaced the whole oven.
Mine is still under warranty so I am still debating on taking it in to be fixed or just leave it like it is with my clamp.
If you are not comfortable working on it take it to your dealer and see if they can fix it. With it being a 2014 you should be under warranty.
Good luck
2004 Dodge Ram 2500HD Cummins
2017 Keystone Montana 3820 FK
2009 Harley Davidson Ultra Glide
kc8lvy is offline   Reply With Quote
Old 09-08-2013, 04:24 PM   #3
Thanks for the tip. I'll try it out
Old 09-08-2013, 04:49 PM   #4
kc8lvy's Avatar
Your pilot light should still burn blue with hardly any yellow.
I do not leave my pilot on if I am not using the oven. edit: if my wife is not using the oven.
Old 09-09-2013, 10:39 AM   #5
The pilot goes off while using it - we get the pilot lit, then set it to temperature. Once it gets to temp the whole thing turns off. Happened each time we used it.
Old 09-09-2013, 12:56 PM   #6
kc8lvy's Avatar
If my mod did not work I would call your dealer and they may have to replace some parts
Old 10-21-2013, 02:24 PM   #7
I'm having the same problem with the oven in my 2012- 8312SS, I have already tried adjusting the pilot flame by the adjustment screw on the valve but no luck the flame doesn't change at all when I turn the screw, I'm thinking it may be a bad valve. I'll try your mod kc8Ivy and see if that helps if not I'll take it in for warranty over the winter. Thanks for the tip.
trainwreck68 is offline   Reply With Quote
expandable, hybrid, shamrock
