Old 06-23-2015, 04:13 AM   #1
wicked1's Avatar
Oxygenics On/Off Switch
Ok so replaced shower with Oxygenics but the water stop switch does not completely stop the water it still leaks from the shower head? Anyone have this happen and know how to fix it?
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 06-23-2015, 05:19 AM   #2
crunchman12001's Avatar
The on/off switch is doing that so you get a constant temperature when you turn the water back on. This is normal and is desribed in your instructions.
Do a search above and you will see 100 threads on it.
crunchman
2015 F-250 FX4
Old 06-23-2015, 05:25 AM   #3
Yes. It's not actually a shut off switch. It's a flow regulator and is designed to minimize water usage while lathering, but maintains a small flow to help maintain water temperature. It helps prevent getting momentarily scalded or get hit with freezing water when you turn the flow back on.
A lot of folks will pick up a full shut off valve from the local hardware store and install it either between the shower head and hose, or at the hose inlet at the fixture.
rana is offline   Reply With Quote
Old 06-23-2015, 05:59 AM   #4
Canadian Member
itat's Avatar
I added a shut off valve on mine when I installed the Oxygenics earlier this year but I found you get a blast of cold water when you open the valve. Apparently, that's what the flow limiter prevents. I'll probably take the valve off and put the flow limiter on.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 06-23-2015, 06:57 AM   #5
Installing a Total S/O valve in a RV or Home and having it perform without the (Blast of Cold or Hot Water) is very dependent on How the system is installed! Location of Water heater to point of usage is Very critical! Not all RVs are plumbed the Same,therefore a S/O valve might NOT give the Same results for all! Ours works fine in our unit. Youroo!!
Old 06-23-2015, 07:11 AM   #6
If you decide to install your own shut off valve at the fixture, you should loosen the fixture itself, rotate it a few degrees from level (as pictured above), then tighten it back down to get the best results.
Old 06-23-2015, 09:19 AM   #7
Timex's Avatar
Give him a break, he's YouRoo!
Maybe he wasn't level front/back?
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 06-23-2015, 09:28 AM   #8
If All my Stuff was PERFECT you guys would not have anything to Look for! Youroo!!
Old 06-23-2015, 09:30 AM   #9
Is that a nice way of saying he might have over indulged?
Alrighhhhhttt.. Sorry Youroo. Just too tempting not to mess with you.
Old 06-23-2015, 09:35 AM   #10
Thank goodness THAT'LL never happen, right?!
