Old 08-23-2014, 09:45 PM   #1
23ss ROOster
Wags2237's Avatar
Smile Periodic sound of water running
We have a 2012 23ss ROO. While parked outside of our home, plugged in, we hear every 5 min or so the sound of water cycling from the area of the water heater, water pump, water filtration. We do not have the water pump nor water heater turned on at this time. Very little to no water in fresh water tank at this time. We did hook up to city water and tested water pump and water heater a few days ago. What makes this water cycle come on? Is it causing any damage to water pump or water heater with no water being pumped from fresh water tank? Any thoughts on this?
Wags2237 is offline   Reply With Quote
Old 08-24-2014, 01:39 PM   #2
If u are hooked up to city water the water should not be cycling. Even when using the tank the water pump should only cycle when water is being used.
2008 F150 v8 5.4
2015Rockwood Roo 23SS
2015 Nights Camping: 39
2016 Reserved: 23
Davylee is offline   Reply With Quote
Old 08-24-2014, 09:24 PM   #3
WFD
You say you can hear water cycling....but your water pump is turned off...so you just hear water flowing? Not the actual water pump? You say you connected to city water...are you still connected? If so, and your pump is off as it should be if connected to city water, and you hear water flowing, then it has to be coming out somewhere. Do you have one of the onboard water filters? If so, check it asap, as it may be leaking in your trailer. Are you sure all taps are off, including outside shower if you have one. The amount of water in your holding tank is irrelevant if your water pump is shut off.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 08-25-2014, 01:50 PM   #4
Jimandchris's Avatar
Bad water heater pressure relief valve?
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 08-25-2014, 02:12 PM   #5
Alleged curmudgeon
Vern's Avatar
Must be a puddle somewhere. Find that and look up.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 08-25-2014, 02:49 PM   #6
WFD
Shouldn't be....OP stated that water heater is shut off....faulty relief valve may do that for a bit while water is hot, but after it has cooled that would stop....I agree with Vern....must be a puddle somewhere...inside or out.
OP has not replied yet as to whether or not they are still hooked up to city water.
Old 08-25-2014, 04:19 PM   #7
I agree, just a shot in the dark on the relief valve.
2014 Roo 23SS
2013 GM Sierra CC
Equal-i-zer Hitch
Old 08-25-2014, 05:00 PM   #8
Infractee
My vote is for a miswired switch to your water pump. Disconnect your battery and shore power and I would bet a shiny penny that your noise stops.
RhoZeta is offline   Reply With Quote
Old 08-28-2014, 11:36 AM   #9
Is it possible the valve at the pump is bad and letting water from the city hookup fill your fresh water tank?
electrician549 is offline   Reply With Quote
water
