Old 05-11-2015, 01:42 PM   #1
Picking up NTU roo this week. What accessories?
I am coming from a pop up so I have the extension cords, leveling block set, 30 amp to 110 adapter, grills, cooler, chairs, tv. What I'm looking for is anything specific I need for a hybrid that I may be missing
Today I bought the following
15' rhino sewer hose with clear elbow
Saddle setup for sewer hose
Pressure regulator
New awning LEDS since I gave the other set to the couple buying my pup
Camco wheel lock
Thanks for any input!!
wraenking is offline   Reply With Quote
Old 05-11-2015, 02:22 PM   #2
RooVader's Avatar
I know a lot of people say Popup Gizmos are the best mod they have done. At the least maybe some Ecofoil/Reflectix might be a nice thing to have if needed.
RooVader is offline   Reply With Quote
Old 05-11-2015, 02:54 PM   #3
bikendan's Avatar
Yep, PUGS are #1 mod for hybrids.
Old 05-11-2015, 05:12 PM   #4
You seem to have your bases covered. Hybrids are just pups on steroids . Just a little bigger with a little more stuff. Going from our pup to our ikss about the only extra I carry is a cordless drill for the stabilizers. Have fun.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
jking46 is offline   Reply With Quote
Old 05-11-2015, 05:21 PM   #5
Thanks for the tips guys
Old 05-11-2015, 05:56 PM   #6
Anderson Levelers
While not hybrid-specific, they sure make leveling a dual-axle trailer fast and easy. If I knew about these when we had our PUP, I would have chosen them over the BAL leveler in a heart beat.
We haven't used our Lynx blocks for leveling our Roo since buying the Anderson's. Instead, the Lynx blocks get used under the stabilizers to shorten the distance they need to extend (which seems to help with stability).
Another "nice to have" X-Chocks. Again, not hybrid specific but great for dual-axle trailers.
Martingale is offline   Reply With Quote
Old 05-11-2015, 06:26 PM   #7
I'm getting a roo 21ss. Did your levelers fit or did you have to trim
Old 05-11-2015, 08:24 PM   #8
We have a 23IKSS and had to trim the Anderson levelers. I only trimmed one but will be trimming the other as well. Reason being, that if you only trim one and then you place both against the tires at the same point, then the rear tire ends up a little higher than the front due to it lifting a little higher/a little sooner than the untrimmed one.
No reason not to trim them both - I don't think. The first inch or two are doing almost no lifting anyway.
accessories, roo
