Old 08-13-2016, 11:48 AM   #1
urocav2001's Avatar
Plug
Do the make an adapter to plug two of the furrion plugs together to make the cord longer? I have two furrion factory cords. Thanks
urocav2001 is offline   Reply With Quote
Old 08-13-2016, 04:31 PM   #2
I'm a little confused.......
Are you talking of the 30 amps electrical cords !
Drenjoey is offline   Reply With Quote
Old 08-13-2016, 04:38 PM   #3
urocav2001's Avatar
Yes the factory 30 amp cords I got two of them I'm wondering if there is an adapter to convert the end that plugs int the unit to be able to plug into another cord
Old 08-13-2016, 05:17 PM   #4
I've never heard of a 30 amp female to female adapter. You might have to get two female end connectors and wire them together. Could be a bit expensive; the end connectors seem to run about $30 each.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 08-13-2016, 05:24 PM   #5
urocav2001's Avatar
Maybe it's easier just to hack one of them ends and put a new connector on it? I got the cords for free
Old 08-13-2016, 05:27 PM   #6
Now you're THINKING!
(Wish I'd thought of it!)
Old 08-13-2016, 07:39 PM   #7
Head Rambler
What you have is a male 30 amp RV plug on one end and a 125 volt 30 amp twistlock female on the other end. So what you need is a 125 volt 30 amp twistlock male plug to a female 30 amp RV plug, in order to connect the two cords together.
Something like this... Voltec Generator Adapter 4 Prong 30 amp
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-14-2016, 09:59 PM   #8
urocav2001's Avatar
Exactly! Thank you
