Old 11-01-2014, 05:43 PM   #1
plug on hot water tank?
We took the plug out of our pop up camper hot water heater. We bought it used. It looks like the plug needs to be replaced. Where would be buy one?
kellieh04 is offline   Reply With Quote
Old 11-01-2014, 06:04 PM   #2
Oaklevel's Avatar
Don't know what water heater you have but any RV store or Camping World.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 11-01-2014, 06:08 PM   #3
Thank you. Would it be okay to use our water hose to spray out the stuff in their?
Old 11-01-2014, 06:25 PM   #4
Mr. Dan's Avatar
Yes.
Do a search for anode rod. I assume that is to what you are referring when you say plug.
Old 11-01-2014, 06:37 PM   #5
Here's the Camping World one. Pic of new and used (what your's probably looks like).
Suburban Anode Rod Replacement - Suburban 232767 - Water Heaters - Camping World
Mine's starting to look like the one in the pic after 3 seasons.
2011 Traverse LT, 3.6L, FWD
Old 11-01-2014, 06:48 PM   #6
$15 on Amazon
http://www.amazon.com/Suburban-23276...rban+anode+rod
Les & Heidi Kramer
2021 Jayco Melbourne 24L
Olmsted Township, OH
cpd1343 is offline   Reply With Quote
Old 11-01-2014, 07:36 PM   #7
Cyber Phrenologist
Radio's Avatar
Yes, and recommended. CW (and other places) sell a water heater rinse out tool. It's a long skinny nozzle that will fit through the plug hole in the water heater and does a jam up job rinsing the thing out.
About $7 if I remember correctly.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
Radio is offline   Reply With Quote
Old 11-01-2014, 08:23 PM   #8
Thank you everyone! Yes mine looks like the picture you posted rockfordroo. I think I will try and get to CW on Monday to replace the anode rod. I'm not sure the brand name of my heater but I will bring the rod and hopefully they should be able to tell me which one I need.
Old 11-02-2014, 09:24 AM   #9
Ret E-9 Anchor-clanker
donanddona's Avatar
Don't forget that plug (on mine) takes a 1 1/16" scoket.
donanddona is offline   Reply With Quote
Old 11-02-2014, 09:55 AM   #10
MtnGuy's Avatar
Pop-up ?? Thought you had a Roo ??
This a picture of my anode rod from a couple of weeks ago when I winterized:
That is after 6 years of use, and should be good for a bunch more years. They do not need to be replaced unless they are more than about 75% deteriorated. Mine is probably only about 25% gone.
Old 11-02-2014, 10:02 AM   #11
Keiiieh04, to clean out the (Crud/Junk) inside the W/Heater, go to any place that sells (Washers/Dryers) and ask them for a (OLD) washer supply hose,they replace them with NEW when installing! Cut the hose in 1/2 and Now you have a (Water Heater Cleaning Hose) (FREE) just screw on a garden hose and place in the (A/Rod-Plug hole) and watch the (Crud/White Crap) come out of your Heater! Youroo!!
Old 11-02-2014, 10:03 AM   #12
Herk7769's Avatar
Here is a chart to give you some idea of when to change it and some ideas on how to flush out the gunk.
REMEMBER to ALWAYS close the bypass valves when removing the anode and flushing to avoid that gunk from getting swept into your cold water pipe.
ID:	65747   Click image for larger version
ID:	65748   Click image for larger version
Name:	Hot Water Tank Clean out Wand.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 11-02-2014, 03:15 PM   #13
Oh wow!!! You all are the best!!!! This helps me a lot!!!! Thank you very much!
hot water, tank, water, water tank
