Old 08-03-2015, 10:59 AM   #21
I used the self adhesive heavy duty velcro and stapled it about every 6". So far works great. I leave them attached when traveling and have had no problems.
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
cabranch47 is offline   Reply With Quote
Old 08-03-2015, 11:09 AM   #22
RooVader's Avatar
What do you mean you stapled it? Mine stays attached to the PUGS just fine because I "sewed" it on (using the term sew loosely). The place it is not staying attached is against the metal flat piece on the camper. I am wondering if it has been too warm or I haven't given it enough time to set because it just pulls right off leaving the goo behind. It isn't even lasting long enough for me to worry about prying the two velcro pieces apart...just drops off the camper.
XLR 24HFS -> Roo 21DK -> RPod 183g
2013 F150 FX4 EB
RooVader is offline   Reply With Quote
Old 08-03-2015, 11:48 AM   #23
Not sure what "metal piece" that you are trying to glue to. Is it the metal trim/seal around the bottom of the roof? I installed mine behind and above the metal trim, there is wood there that the metal is mounted to.
cabranch47
1999 Ford F150
Old 08-03-2015, 12:25 PM   #24
RooVader's Avatar
Right in front of the tent attachment point in the bunk openings there is a flat "ceiling"...that is where I have been trying to attach them. I think it is metal...it is black.
2013 F150 FX4 EB
Old 08-03-2015, 12:26 PM   #25
Jimandchris's Avatar
RooVader, I believe that cabranch47 has a popup, so they are able to staple the velcro up underneath the top. Wish we could though.....
2014 Roo 23SS
2013 GM Sierra CC
Prodigy P3 Brake Controller
Equal-i-zer Hitch
Nites Camped 2016 -25
Jimandchris is offline   Reply With Quote
Old 08-06-2015, 10:03 PM   #26
ycj
Hi. I spoke to Bob at Pop Up Gizmos the other day about the Velcro. He suggested a thin bead across the top with Gorilla glue and then put the Velcro on top. He strongly suggested not screwing or stapling anything. Ordering my Gizmos this week. Good luck!
ycj is offline   Reply With Quote
Old 08-07-2015, 09:30 AM   #27
Hi Roo, My bad, I did not realize that you did not have a popup when I responded about stapling to the roof. Hope you solve your problem as I am a believer in the Gizmos.
cabranch47
1999 Ford F150
Old 08-07-2015, 09:50 AM   #28
RooVader's Avatar
No worries at all! I am a big believer as well...even if I never get my velcro working I will continue to use them. They make a huge difference and I am always shocked that I have never seen another popup or hybrid using them besides me.
2013 F150 FX4 EB
Old 08-10-2015, 07:56 PM   #29
I love mine. I have the high wind ones with the bungee cords that wrap around. I didn't use Velcro, I tuck the top edge into the rain gutter. My PUGs are left over from my popup, they are bigger than my bunks but it works.
Uncle Buck is offline   Reply With Quote
Old 08-11-2015, 10:35 PM   #30
pxt
Hot glue and gun would do the trick
pxt is offline   Reply With Quote
pop up
