Old 03-02-2012, 04:20 PM   #11
iluvlcy's Avatar
I so wish we had vinyl floor under our table,does not take long for carpet to look worn.
Pam & Don
2003 Ford Expedition EB
2011 Rockwood 2304s
108 days camped 2013
74 days camped 2014 so far
iluvlcy is offline   Reply With Quote
Old 03-02-2012, 04:28 PM   #12
Barney1's Avatar
Oops photoshop error! That should be carpet!!
And I spent all that time making sure the tiles aligned. Oh well.
Barney
2012 Rockwood Roo 233s
2011 Ram 1500 Big Horn V8 Hemi
Previous Trailer -> 1996 Jayco 1207
Barney1 is offline   Reply With Quote
Old 03-02-2012, 08:51 PM   #13
Barney1's Avatar
Here is the corrected image - with carpet.
Barney
Old 03-02-2012, 09:08 PM   #14
Fire Instructor's Avatar
We were actually glad to get away from the pedistal mount in our previous HTT, and get to more portable folding leg table. We've took it outside once as an extra serving table for an impromptu campground picnic, and we've pulled it in front of the sofa to do a puzzle... Additionally, without the floor-mount hardware in the way, we use the space under the table for in-travel storage of items that get used outside once we get to our destination.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 03-23-2012, 10:11 PM   #15
We just got a 23SS on Monday and as others have said, the table wobbles so much that it is almost unusable. We play lots of games at night and this will be a problem. I looked at where the flex is happening and it looks like the screws are not driven in flush. Are they all like this?
Thanks!
DisneyFamly is offline   Reply With Quote
Old 03-26-2012, 12:48 PM   #16
Barney1's Avatar
There is a high possibility I might do this mod. I just found someone who has done it.
Darn I thought I was being original.
It appears that this mod is on a slide out too
This looks like a FF Wildcat 28RKX - Year ??? But the bench seats are a clue to age
Dinette Table 3-stage Telescoping Pedestal Upgrade/Mod
Barney
Old 04-01-2012, 12:46 PM   #17
BeagleIL's Avatar
If I were to attempt this mod, I think I would use a heavy restaurant table base like you are proposing. But I also think I would search the home improvement stores for a formica table top that is close in size and not modify the Rockwood table. Good to see how it works first without possible destruction or alteration of the factory piece...
BeagleIL is offline   Reply With Quote
Old 05-29-2012, 03:27 AM   #18
jbdbsb
jbdbsb's Avatar
I love the U-dinette, wish mine had it. I hate the bulky heavy wobbly combersome dinette table.
jbdbsb is offline   Reply With Quote
Old 05-29-2012, 07:17 AM   #19
I would definitely mount a support plate under the slide floor as well, if there is room. It would work on our camper's slide.
The under-floor support plate could be bolted to a base plate above the floor, making sure to cover two floor "joists" with the bottom plate, using carriage bolts with the nuts on top. That would minimize the interference with the slide seal.
Then the telescopc base could be attached to the base plate. That would result in a very strong table, and no worries about damaging the floor from someone pushing down on one side of the table.
A bit more work, but definitely a superior result.
Just my 3 cents!
DonG is offline   Reply With Quote
Old 05-29-2012, 11:39 AM   #20
Barney1's Avatar
The DW vetoed the mod. She likes to be able to move the table around
Barney
