Old 06-29-2016, 09:26 AM   #1
power issue
So my dual LP/CO detector will start beeping at random times. The light pattern indicates a fault or low voltage per instructions on the face of it. My battery is holding a charge of 12.5-12.6 volts, which is still around a 90% charge. So I don't see how it could be due to low voltage. If I am plugged in at my house or any campground that has AC hookup. It will stay green and will not beep at all. I have also noticed that when I bring my slide in it will blow a fuse every time if I am just using the battery. Any thoughts? I have a 2015 Roo 21BD.
JDZO6C5 is offline   Reply With Quote
Old 06-29-2016, 09:29 AM   #2
Can anyone post a picture of their manual slide crank tool? When my slide wouldn't go in with the battery. I searched for that tool and couldn't find it. I may not have been provided it at time of purchase from dealer. The only cranks I have is for the jacks and the power tongue jack. Thanks.
Old 06-29-2016, 09:37 AM   #3
TURBS's Avatar
Id say its a fault in the co detector.
What size fuse is used for the slide?
Replace fuse with an auto reseting ato circuit breaker.
Sent from my SCH-R530U using Tapatalk
Old 06-29-2016, 09:40 AM   #4
Thanks. The fuse for the slide is the green 30amp fuse.
Old 06-29-2016, 09:41 AM   #5
Sham183
I would check ground connections. You might have a issue with wiring. Check connection at the battery too. If you have a loose ground it can cause issues when a draw is being put on the system and if it sparks enough it can cause the fuse to pop. Think of electricity as water, it will follow the path of least resistance and if there is a break it will take it and cause problems for you. Make sure all connections are clean and tight.
mopwr4me2003 is offline   Reply With Quote
Old 06-29-2016, 10:24 AM   #6
TURBS's Avatar
Looks like this.
Any auto parts store will have it available.
power
