Old 04-02-2016, 09:43 PM   #1
fedrocker's Avatar
Power to only half the outlets
I'm camping now and only half the outlets have power to them - I've tried the breaker outside and also the breaker box inside. Any ideas?
2011 Rockwood Roo 233s
2007 Tundra Crewmax, 5.7
fedrocker is offline   Reply With Quote
Old 04-02-2016, 09:55 PM   #2
Bluepill's Avatar
You probably have a tripped GFCI outlet.
That outlet and others "Downstream" of it will be dead when it trips.
2008 Itasca Meridian 37H
Old 04-03-2016, 08:14 AM   #3
fedrocker's Avatar
Found the gfi trip - outlet near the door. All good
Old 04-03-2016, 02:30 PM   #4
urocav2001's Avatar
I had this problem as well but it wouldn't reset, found to be a bad gfi plug itself.
urocav2001 is offline   Reply With Quote
Old 04-03-2016, 03:12 PM   #5
fedrocker's Avatar
I'm lucky ...
Old 04-03-2016, 03:14 PM   #6
asquared's Avatar
We had this issue in our first tt... turned out we had hooked the battery up backward and blown 3 fuses.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 04-03-2016, 03:40 PM   #7
SeaDog's Avatar
I split my circuits up to stop the tripping RV wired all on the same breaker and GFI
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 04-07-2016, 06:15 AM   #8
pkenley's Avatar
GFI
One of my gfi breaker is in the bathroom.
Phil & Carla Kenley
2014 Rockwood ROO 21ss
2013 Ford 150 Platinum Crew Cab
(Looking at the Georgetown 329DS)
Nights camped in 2011/16; 2012/15; 2013/48;
2014/10; 2015/101 2016/55 yr to date
pkenley is offline   Reply With Quote
power, electrical
