Old 02-03-2014, 04:22 PM   #1
2014 233s Rockwood Roo
Power tongue jack problem
I went to pick up my 233S Roo and the power tongue jack wouldn't work. So I figured my battery was dead because it was been about 3 months since we had it out. I brought the battery home to charge and it wouldn't take a charge. So I got a new deep cycle battery. I still had the original in there and wanted to change it out anyways so no big deal. I put the new battery in there and it still is not working.
I got up under the front of the unit because my neighbor who had forest river different make and model said there was a reset button you have to push if you remove the battery. I tried that and still no luck.
Am I missing anything?
Thanks!
WFDEric is offline   Reply With Quote
Old 02-03-2014, 04:25 PM   #2
Ford Idaho's Avatar
Did you have the jack head covered with something?
Some have had water get in the jack and ruin it.
https://www.google.com/search?q=powe...iverforums.com
Old 02-03-2014, 04:27 PM   #3
fonzie's Avatar
Usually there is an in-line fuse for the jack from the positive post of the battery.
Fonzie
Old 02-03-2014, 04:31 PM   #4
Plug into your tow vehicle and try it. If it works then, you have an inline fuse problem. This happened to me some time ago and drove me crazy until I replaced the fuse block. It will be located a short distance from the positive line off the battery under the frame. Use a volt meter to check both sides of the fuse for power, if none after the fuse that is the problem. Good luck.
dparkpa is offline   Reply With Quote
Old 02-03-2014, 04:33 PM   #5
Triguy's Avatar
That's the first thing I would check, too. If its an LCI jack (which is a common OEM jack) than the 30A fuse is located by following the RED power wire beneath the jack. Its a 30A ATO-type fuse.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 02-03-2014, 04:37 PM   #6
Light on the front of the jack lights up. I checked the 30amp fuse and it looks good.
Old 02-03-2014, 04:39 PM   #7
I did end up using the manual jack. All I did was take off the top level then cranked away to move it up. I could hear the motor making sounds as I was turning it. Was I suppose to disengage the electric motor some how before doing this?
Old 02-03-2014, 04:44 PM   #8
fonzie's Avatar
No the motor can not be disengaged.
Fonzie
Old 02-03-2014, 04:44 PM   #9
bikendan's Avatar
first, if you don't have a battery disconnect switch, the trailer's parasitic power drains will empty a battery in just a few days, if it's not plugged into shore power.
second, many new owners accidently cross the battery wires, when installing the battery. this trips a gray or silver resettable breaker/fuse that is along the A-frame, between the battery and the front of the trailer.
there's a tiny black button you push to reset the breaker/fuse. this will restore 12v battery power to the trailer.
or the fuse along the battery wire has blown.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 02-03-2014, 04:59 PM   #10
Triguy's Avatar
I think your next step is to check with your multimeter that the jack's motor is getting power. Assuming it is, than the jack probably needs to be replaced and you are still under warranty.
Our first jack's motor on our current camper failed after three months.
Scott
2012 Shamrock 233S
power
