Old 04-03-2015, 08:33 AM   #1
fedrocker's Avatar
Pressure release valve
The pressure release valve on my 233s' Suburban water heater is a bit hard to open - is it supposed to have a lot of resistance? Afraid of breaking it before I head out on vacation.
Thanks.
fedrocker is offline   Reply With Quote
Old 04-03-2015, 08:39 AM   #2
TURBS's Avatar
It's should have a fair amount of resistance,
TURBS
08 duramax tuned n modded, 32bhok Sabre
Old 04-03-2015, 08:43 AM   #3
fedrocker's Avatar
Thanks TURBS. It seems that the hinge is set where the bottom of the valve's switch rubs against the adjoining metal.
Old 04-03-2015, 08:47 AM   #4
fedrocker's Avatar
And also - is it supposed to stay in an open position?
Old 04-03-2015, 09:40 AM   #5
bubbles's Avatar
Open position is when the lift tab is sticking straight out from the valve not flipped all the way to the opposite direction. But maybe you understand this.
Old 04-03-2015, 09:43 AM   #6
No, it is not supposed to stay open. It is just so you can momentarily open it or if you get it to stay in the open position, it will drain the tank spew water until there is no pressure and the water level reaches the valve level.
Old 04-03-2015, 09:51 AM   #7
bubbles's Avatar
I thought he meant without holding it open?
Old 04-03-2015, 09:54 AM   #8
DaveSchwartz's Avatar
You shouldn't lock it open for too long (i.e. over winter) because the extra compression of the spring will weaken it and you could start having leakage at lower line pressure.
I only ever open it when winterizing, after removing the anode rod, for a fast drain. Also when de-winterizing to get a fast fill via the pump or city water (purge the air without having to open a hot tap somewhere).
I've only ever had the pressure relief valve do its intended job when I've completely filled the system with cold water and then had the water heater come up to full temp without opening any tap during the process.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 04-03-2015, 09:58 AM   #9
You can also get a fast drain if you remove the anode rod/plug and then go open all the hot water faucets. It will suck the water out of the faucet lines.
Old 04-03-2015, 01:37 PM   #10
fedrocker's Avatar
Thanks - I am actually done dewinterizing (all the antifreeze drained of course). I am reversing the bypass on the hot water heater and filling it up. So I want to release the air pressure so I can fill it up all the way with water.
pressure
