Old 06-27-2016, 09:20 AM   #1
Dannyboy76's Avatar
Prewired backup camera
My Shamrock is prewired for a backup camera with a mounting bracket. Over the bracket is says to go to furrion.com for the camera. I went to their website, made some research and saw lot of rv'er having bad experience with Furrions product and their product are really expensive. Anyone know if the prewired and mounting bracket fits other brand of camera?
dannyboy76
2011 Honda Pilot EX-L AWD
2016 Flagstaff shamrock 183
Dannyboy76 is offline   Reply With Quote
Old 06-27-2016, 01:02 PM   #2
Old Eeyore's Avatar
The prewiring consists of providing power for the wireless camera. (The trailer's lights have to be on to get that power.)
Basically you'd have to cover the fairly small hole under the plate and I see no reason why you couldn't substitute another wireless brand.
FWIW: We went ahead and bought the High-Speed Observation System and have had zero problems. (Well - one initial problem. But Furrion can't be held accountable for FR installers who don't know how to properly install solder-less connectors.)
2016 Roo 23IKSS / 2011 Tahoe
2011 Roo 21SS / 2011 Tahoe
2006 Bayside / 2006 4Runner
1999 SantaFe / 2001 Sienna
1967 Nimrod / 1998 Outback
Old Eeyore is offline   Reply With Quote
Old 06-27-2016, 01:14 PM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
No reason why you can not remove the mounting bracket that is there and then install the system of your choice. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 06-27-2016, 02:00 PM   #4
The only reason I can think of you can't, is you have a very irregularly sized bracket about 6" x 3" and a gasket that is caulked in with geocel. The 4 screws holding that were zipped in without pre drilling, and then they were stripped resulting in blowing out the gelcoat. Under that gasket they have a 3/4" hole which looks like they hired a rat to gnaw through the wall. I had mine off last night to see if it was wired into the running lights or the backup light circuit (center pin on 7 way).
On a 2017 Roo 23WS it is wired into the running / clearance lights. I sort of figured FR would not have taken the time and expense of running a dedicated wire from the A frame to that camera since a Roo has no backup lights to require it.
As much as I do not like Furrion, and like them even less since they jumped in bed with LCI, I did break down and buy the observation camera for around $350 at Amazon.
Mr Havercamp is offline   Reply With Quote
Old 06-27-2016, 02:14 PM   #5
Dannyboy76's Avatar
Thanks for the feedback, I will look on how the bracket is made, I will search over amazon and ebay if I can find something that can transmit over bluetooth or wifi on my phone since I already use it for GPS and to listen music. It is already well installed on my dashboard.
dannyboy76
Old 06-27-2016, 02:29 PM   #6
aceinspp's Avatar
Yes the bracket is odd shaped but only one hole for wires to go through and two screws that hold bracket into place at least that is how mine is and yep wired in to clearance lights. If he finds one with a bracket to cover mounting hole go to go. Later RJD
Days camped 2017 62
Days camped 2018 18
Old 06-27-2016, 08:04 PM   #7
Anyone know if the 23IKSS pre waiting is connected to backup lights or parking lights? If parking lights, then it could be used while driving to see if anyone is on your tailgate
Sent from my SM-G920V using Tapatalk
ESDSKeith is offline   Reply With Quote
Old 06-27-2016, 08:41 PM   #8
Blog: RVroadtripper.com
hbillsmith's Avatar
The Furrion camera with 48 in the model number is the way to go. Cheaper on Amazon but if you buy direct they will knock off 10% if you sign up for the newsletter. Most Furrion complaints refer to the model with 12 in the number. I've had the 48 a little over a year and like it.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 06-27-2016, 09:13 PM   #9
Old Eeyore's Avatar
It's wired to the running lights. I have to have the Tahoe's headlights turned on - not on auto.
I installed #FOS48TA-BL - their "High-Speed Observation System" and I use it like a rear view mirror. I actually hang the monitor on the mirror. At least when I look up there out of habit I actually see something besides the front of the camper!
Helps a bit backing into campgrounds, gas stations, etc. But don't expect to see too much detail.
Old 06-27-2016, 09:17 PM   #10
BandJCarm's Avatar
Have the Observation Camera. It went 'out' 200 miles after picking up trailer.
Turned out it was just a loss of 'pairing'..........a bluetooth issue. 40 foot trailer, 22 foot truck, they're a long way apart. Loss of pairing understandable.
Paired them with help at campsite this week, made it home just fine with it working.
I do wish it was pointed 'further back' and not just down at my bumper. I can't see a car coming up on me unless it almost touches my bumper on trailer. Great for backing up, not so much for lane changes on I-whatever.
FROG AR-0019-242
BandJCarm is online now   Reply With Quote
