12-08-2017, 02:37 PM
Probably a stupid question on freezing temps
My camper is several hours away. They are calling temps to be between 27 and 32 degrees for roughly 4 hours. My tanks are not full, but there is water in the lines. Is it almost guaranteed my lines will burst?
2017 233s Shamrock
2015 King Ranch F150 4x4 EB
Blue Ox WDH
12-08-2017, 02:43 PM
The only guarantees in life are death and taxes. Not necessarily in that order either...
You *might* be OK if it's only for a couple of hours. The water won't freeze instantly. But then again, when is the weatherman ever accurate?
It's really hard to say either way.
12-08-2017, 02:46 PM
Likely no.
Things do not freeze the instant it gets to 32º. It can take many hours.
An example, lets say your camper sat in some sun today and the inside temp got to 45º... it will take hours even at 32º outside before the inside gets to freezing.
But lets play devils advocate... you say it's only to get 27-32º for 4 hours.
What if they are wrong and it is 24 hours?
With that said... if there is any possibility you could visit and turn on the furnace or run an electric heater, it would be good insurance. Better yet, winterize it.
12-08-2017, 02:48 PM
Very true. Could stay a bit warmer but can always get colder. I guess I will see. It's very rare we see temps this low and I had planned on being up there before now.
Thanks! Fingers crossed!
2017 233s Shamrock
Blue Ox WDH
12-08-2017, 02:54 PM
It won't hurt the PEX tubing, but the fittings and tank valves could be of issue if it gets ??20 deg??? and stays there. YMMV
2017 Puma 297RLSS
12-08-2017, 03:39 PM
I think you'll be fine if it's only for 4 hours...
One thing I always do after every trip, even if its warm, I open up the drain lines and all the spigots to drain the water out of the system... I'd rather not have that water stagnating in the pipes... And if it were to get cold, what little water you have left in the system, even if it froze would have room to expand be less likely to break anything...
Gerry Z
2018 Forest River Heritage Glen 272RL
2018 Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
HD Roadmaster Active Suspension
3200 Firman Generator/Inverter
12-08-2017, 03:48 PM
Living in Florida, I doubt that you have anything to worry about.
I never winterized my Roo when I lived in NorCal.
12-08-2017, 04:41 PM
Just as confused as you
Except for the toilet flush valve, 1/2 teaspoon of water in the valve can crack it.
Richard & Jill
12-08-2017, 05:07 PM
I blow that out for the winter... I do however wonder if the lower drains were open and you press the foot switch, would it drain out like the spigots??
Gerry Z
Curt Trutrack WDH
12-08-2017, 05:13 PM
Maybe, I've experienced water in the bowl ring and supply line to trickle back down into the valve once closed, especially if you don't use compressed air to blow out... and even then sometimes. I wouldn't trust it.
12-08-2017, 05:21 PM
Yeah - I use compressed air to blow it out but you're prolly right Picker, no sense taking chances...
Gerry Z
Curt Trutrack WDH
Jacksonville weather service says it may be below freezing for 4 to 8 hours. I don’t know where your rig is located, but we never winterize and have never had a problem in Gainesville area.
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
12-08-2017, 05:24 PM
Likely no.
I have never seen it stay below freezing for 24 hours in Florida. It rarely stays below freezing beyond eight or nine in the morning. To have a high in the forties is very unusual. Usually the high is in the fifties, even in January and February.
12-08-2017, 05:32 PM
Thanks. She's is just North of you in Valdosta.
2017 233s Shamrock
Blue Ox WDH
12-08-2017, 05:51 PM
I spent Dec/Jan/Feb in Orlando for Navy boot camp in 1970-71, and I can tell you - it got below 32 degrees for more than 24 hrs. Maybe not these days, if global warming is reality....
2011 Traverse LT, 3.6L, FWD
12-09-2017, 01:45 PM
Spend 15 bucks and 15 minutes
Winterizing is not an arduous task. I prefer to be on the safe side. The alternative is very inconvenient and expensive
12-09-2017, 01:57 PM
To answer the OP question...I wouldn't give it a second thought. Very unlikely to have low enough temps for long enough to freeze anything.
I was also in Navy RTC in Orlando, right after you. Yep, it got cold out on that grinder in Jan-Feb waiting on breakfast before daylight. Company 024, barracks close to the fence and highway.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
12-09-2017, 01:58 PM
If you are not using it I would winterize the system. I do not trust weather forecasts any more either. For the cost of some RV anti freeze and a bit of time its not worth taking the chance when one factors in the costs and hassels of repair and potential damage to your investment. We have seen ice on orange groves in Florida before and right now Texas is in the midst of a blizzard and black ice on their roads.
Even in Canada here to-day its just at freezing.
Brandon2
2014 Sun Seeker.
12-09-2017, 02:28 PM
I would call a local mobil RV repair outfit and have it winterized. Good luck.
12-09-2017, 05:48 PM
I remember a January in Ocala at the Silver Springs Car show and it snowed! It was darn cold that whole weekend! I was glad I was showing the car that has heat!
