Old 08-10-2015, 08:58 PM   #1
rfd15's Avatar
Propane/CO detectors
Anyone have any problems with faulty detectors in their Roo?? I'm on my 2nd one and seems to have the same problem. It chirps and signals low voltage even tho my batteries are reading 11.7v....usually occurs at 4am...
rfd15 is offline   Reply With Quote
Old 08-10-2015, 10:43 PM   #2
rbq
Probably nothing wrong with the detectors if your battery is down to 11.7 volts. 11.7 volts means you only have about 30% left on battery. See the 12 volt side of life.
http://www.marxrv.com/12volt/voltchart1.gif
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 08-11-2015, 01:27 AM   #3
bikendan's Avatar
Yep, battery was too discharged, therefore the chirps.
Anything below 50%, can shorten the battery's life.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-11-2015, 02:54 AM   #4
Mine does that. I wish there was a way to shut the thing off (thanks for the alert; I'll switch over batteries in a couple of hours once the sun comes up).
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 08-11-2015, 01:52 PM   #5
rfd15's Avatar
Thanx for the help...I actually spoke to the manufacturer of the detector, and it shouldn't start chirping until 7v or less..I am by no means a battery guy, in fact, it hurts my head..lol..but just doesn't make a lot of sense to me...
Old 09-07-2015, 12:44 PM   #6
Pixelbum1's Avatar
I finally disconnected mine after the same $%#^&*!! problem, as yours. Previous owner replaced it once from what I understand...installed a CO detector in bed area of my Solera and will use my nose for the LP part. Never had a problem w/o all this stuff
in my previous TT (Airstream) for the 20 yrs. I owned it! Seems to be a problem with
the manfuacturer of the LP\CO detector. Too damned sensitive?
Si Hoc Legere Scis, Nimium Eruditionis Habes!
Pixelbum1 is offline   Reply With Quote
Old 09-07-2015, 09:34 PM   #7
I had the same problem. Propane detector started going off at 11 at night in a state park in Massachusetts. Had to run the tv for a half hour to charge batteries. Lucky for me I had half bottle chardonary and fire wood to keep me occupied. Lol. Also had issues with Co detector, the wife's hair spray caused the Co detector to go off. Turned on fans and it stopped. Smoke detector, removed batteries every time I use the grill or the stove it goes off. Weather the fans are on or off windows open or closed still the smoke detector goes off. Gurrrr! So all 3 detectors have been a real pain.
1st timer is offline   Reply With Quote
Old 09-11-2015, 05:38 PM   #8
rfd15's Avatar
So I'm now on my 3rd detector...different manufacturer than the one that comes with the new Roos...ran down to 8v....no issues...thank god....
Old 09-11-2015, 05:51 PM   #9
Which manufacturer did you go with? Any problems with installation?
Thanks in advance.
Lar & Ruth
Old 09-11-2015, 06:24 PM   #10
Flybob's Avatar
Battery is Low
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
propane
