Old 05-12-2015, 10:25 AM   #11
Hicks43's Avatar
The in line ones just read tank psi. You can check by pouring hot water on the tank and feel where it's cold.
Hicks43 is offline   Reply With Quote
Old 05-12-2015, 10:36 AM   #12
fonzie's Avatar
Here's instructions on my unit......
Fonzie
Old 05-12-2015, 11:23 AM   #13
karrun's Avatar
Thanks everyone for the info. I like the plexiglass window idea to view the indicator. I think we'll keep doing what we are doing and keep both open, and just make sure we top off the tanks before a longer trip.
karrun is offline   Reply With Quote
Old 05-12-2015, 01:07 PM   #14
I still rely on the old fashioned magnetic ones. You just run very hot water over it and it reads pretty accurate. I use one tank at a time. Otherwise it seems I always
have two tanks that are half full. If we are going for a week or so I like to know that they both are full when we leave. Never know where the next fill station is.
syogerst is offline   Reply With Quote
Old 05-12-2015, 01:22 PM   #15
wicked1's Avatar
CW has them for like $7 each so the magnetic ones work well?
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 05-12-2015, 04:06 PM   #16
Yes, no problem with magnetic strip. Probably had this one for 5 or 6 years. Mine fits vertically on the tank. Changes colors to indicate amount of gas in tank.
Old 05-12-2015, 04:25 PM   #17
One tank on, other tank off, nothing to remember or to look at. Automatic notification you can't ignore.
Old 05-12-2015, 04:44 PM   #18
Briorick's Avatar
We have dual tanks and when 1 of them goes empty we have to manually flip/ turn the dial between the tanks so as to show which tank is being used. Red Dot indicates empty tank, Green Dot indicates full tank ( or tank in use ). We learned this last weekend when we ran out of propane. ARGH! At least we though so. Phew!
We, too thought both tanks ran simultaneously. SURPRISE! LOL. Now we know just to refill when one goes dry. You only run out ONCE! LOL
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 05-12-2015, 04:44 PM   #19
yetavon's Avatar
Yup, and if a cold night, turn the 2nd tank on and back off in the morning while making coffee on the stove...you will soon know if your in need of a refill.
2015 Shamrock 21DK
2005 Silverado Ext cab
Nights camped 2017.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 05-12-2015, 05:03 PM   #20
mud yapster's Avatar
We have 3 tanks and I use the old fashioned way like Oldcoot when one runs out I flip the knob to the other tank and know that one needs refilled. I've never been without propane in over 30 years using this method. The tank gauge works off pressure and the magnetic strip works off temp. neither are real accurate you can weigh your tank would be most accurate but who wants to do all that work. LOL I don't mind waiting on one to run out and then turning on another one. LOL
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
cat, propane
