Propane Tank Cover Mod
On my 2012 Roo19, I have a gas regulator that automatically switches tanks. Only problem is, you can't see it unless you remove the cover over the tank. I cut out the "LP GAS" word area, cut a piece of Lexan a bit bigger than the hole and attached it with stainless steel screws/washers/nlyon nuts. Sorry for the two fuzzy pics. My autofocus seems to have had trouble with the all-white cover.
