Old 02-22-2011, 06:39 AM   #11
Smokyroo's Avatar
You wonder why Rockwood couldn't simply weld a piece of steel fore and aft of each wheel to brace the frame as a jack points during the build? Did they not think folks would either experience tire issues while traveling, would need to mount new tires and wheels and do hub/bearing work over the lifespan of the trailer? My other trailers were no better in this respect either.
Bob, Tonya and the kids
11 Rockwood Roo 233S
08 Grady White Seafarer 228
08 Tundra 5.7 liter 4x4 crew cab TRD limited
08 Toyota limited 4 Runner Iforce V8 full time 4WD, tow package
Smokyroo is offline   Reply With Quote
Old 02-22-2011, 07:26 AM   #12
Wanna Be Camper
SaskCampers's Avatar
I carry a 20 Ton bottle jack and lift the trailer between the axles as there is a lip on the frame there. I only lift it high enough to get the wheel off and only remove one at a time to prevent a big bad.
Old 02-22-2011, 08:08 AM   #13
Smokyroo's Avatar
We carry a 20 ton bottle jack too...and wood...mainly for the boat, but it works great for the camper. I have had more flats with my boat trailers than you can shake a stick at..even with good year marathons running on them.
Old 02-22-2011, 08:21 AM   #14
Wanna Be Camper
I get all my flats on my 18ft flat deck and it has Marathons as well. Had 5 flats last summer so I am not overly impressed with Goodyear. Come to think of it on my 04 Ram 4x4 it had Goodyear on off road tires and I had 13 flats in 15 months with those tires, I even had a perfectly round rock go through one.
Old 02-26-2011, 09:37 AM   #15
I carry an EZ Jack Trailer Jack in the back of my truck. We have had to use it three times in the past 18 months and can change a flat in the rain and interstate traffic in less than 15 minutes. No need for special tools, additional jacks, etc.
camper22406 is offline   Reply With Quote
Old 02-26-2011, 11:15 AM   #16
Originally Posted by rthrbelsewhere View Post
Another option a lot of campers use is this:
Trailer-Aid. It’s a wedge that you drive one tire onto and it lifts the other off the ground, leaving it accessible to change the tire.
The problem with this is... while the trailer is being held up on one wheel, you may now be violating that wheel's weight limitation (and the axle weight limit too).
1997 FR Sierra 30RKS
2004 GMC Sierra 3500 Dually CCLB
DageonYar is offline   Reply With Quote
Old 02-27-2011, 07:41 AM   #17
Smokyroo's Avatar
How would this be any more force on the axle? Each axle carries part of the load right? So, if one applies a jack or force to lift the camper are you just not transfering the load from the hub and wheel to behind the it at the jack point? I am confused here I guess.
